Question about Dishwashers
Replace fuse samsung
Replace fuse
Posted by mts547 on
Steve Papp
  • Dishwashers Master
  • 1,010 Answers
It should be at the lower right side, if you have one, or maybe you have just a thermal fuse in the control panel.
First check it, if you have power at the terminal (where the wire goes in)
Posted on Mar 19, 2013
Samsung nc10 charger blowing fuse?
The charge adapter is faulty. You need a new power adapter for your model Samsung notebook.
May 20, 2013 | Samsung NC10-14GW Notebook
Samsung microwave not working
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 02, 2013 | Samsung Microwave Ovens
Samsung dishwasher no power/display off
The Samsung DMR57LFS Dishwasher has a 15 Amp/250VP Volt Fuse located on the lower right side of dishwasher behind an aluminum panel held by two screws. Pull dishwasher out from counter, remove lower rectangular aluminum panel, and it is just inside underneath. Unscrew fuse holder and replace fuse. I had to pay a Samsung Authorized Repairman $109.70 to replace a simple fuse. I learned the hard & expensive way. Samsung won't tell you to check the fuse underneath the unit. They won't even tell you that there is a fuse underneath on the right side. The fuse protects the Printed Circuit Board or Blue LED Control Panel in the event of a power surge or lightning strike.The less than $4.00 fuse will blow first.
Jan 27, 2013 | Samsung DMR57LFS Stainless Steel Builtin...
Samsung fp-t5084 fuse fix is the replacement fuse slow burn or fast burn?
I'm certain it uses a T12amp slow blow type. I have the exact same model, you can replace the fuse. The TV will for a while, but that fuse will blow again. You will need to replace the power supply board for a more permanent fix.
Dec 21, 2012 | Samsung FPT5084 50 in. Plasma HDTV
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
Oct 06, 2012 | Samsung HLN5065W 50" DLP TV
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Cr fuse error?
CR Fuse Error Samsung 4016. Replacement toner cartridge threw this error, found small glass cartridge fuse on top-front edge of cartridge, swapped fuses with my old cartridge, voila. Replacement fuse was good, had continuity, but felt to me to be slightly smaller diameter than original fuse.
Oct 15, 2010 | Samsung SF-5100 Plain Paper Laser Fax
My Samsung TX-R3079WH won't turn on, and the light
replace 5 amp 250 v fuse with 6.3 amp 250v fuse
Mar 08, 2010 | Samsung Televison & Video
How do I check/replace the fuses on a Samsung TXP3271H?
If the fuse is burnt, the wire inside will be broken or/and the fuse is black, if you have tester measure it for conductivity with ohmmeter. Replace with the same ratings fuse. If the TV doesn't power up other parts could be burnt and need replacement
Feb 02, 2010 | Samsung TXP3271H TV
Dishwashers Logo
101 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
