Question about Uniden DECT 6.0 Cordless Phone ID
How do I reset the outgoing message on a Uniden Dect 6.0 cordless phone?
The outgoing message is no longer setup on the phone. How do I reset an outgoing message for the digital answering machine?
Posted by Anna on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Mar 19, 2013
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
Posted on Aug 27, 2008
David Richards
  • 569 Answers
SOURCE: I need an Uniden phone DECT2080 owner's manual.
You can find the manual here:
http://www.uniden.com/pdf/DECT2080om.pdf
Posted on Dec 16, 2009
ABKSeeker
Frank Black
  • 69 Answers
SOURCE: How do I change the outgoing message on my Uniden
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the
messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the
system is in the command waiting mode.
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded
greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
Posted on Feb 15, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Posted on Mar 27, 2010
Testimonial: "thank you very mucy "
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: setting up my outgoing message
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Posted on Jul 22, 2010
Out going message for uniden dect 6.o phone
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Dec 20, 2013 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I set up outgoing message?
Since you didn't state the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 19, 2013 | Uniden DECT 6.0 Cordless Phone ID
How to reset the outgoing message?
Since you declined to specify the model of your Uniden DECT 6.0 system, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/
to download the manual.
Aug 23, 2011 | Uniden DECT 6.0 Cordless Phone
Can't reset outgoing message on the answering machine
Jun 17, 2011 | Uniden DECT 6.0 Cordless Phone ID
Can you set a personal outgoing message on a Dect 1560-2 Phone and if yes, how? Thank you!
No, you can't set an outgoing message since the Uniden DECT1560 isn't an answering machine.
Feb 02, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do you record an outgoing answering maching message on a uniden dect cordless phone?
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Sep 03, 2010 | Uniden DECT 6.0 Cordless Phone ID
How to record outgoing message Uniden cordless answer machine 6.0
Jul 31, 2010 | Uniden DECT 6.0 Cordless Phone ID
Need to reset the outgoing message greeting, forgot how??
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download the manual.
Jun 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Record outgoing message
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest that you select it from the list beginning here to download a copy of the manual.
Feb 06, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden DECT 6.0 Cordless Phone ID Logo
356 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
