Earlier this week my Dishwasher blew its thermal fuse. I replaced the thermal fuse and cleared what I thought was the debris from the grinder area that might have created the problem. Low and behold the fuse blew again - so this time I replaced the main circulation pump/ motor ($135), the drain pump ($60), the grinder ($20), and a new thermal fuse. I also replaced the wires that came with the thermal fuse - per instructions included. The dishwasher now works but hangs around 42 minutes into Normal Wash cycle and 39 minutes into Light/China cycle. At the same time the area on the door where the control panel sits gets hot- more so than the rest of the door. I am worried I will blow another thermal fuse. I am not sure whether the soil sensor/ thermistor needs to be replaced or the main control panel. I tried running the diagnostic (normal>heat>normal>heat) but got nothing. Thoughts on what to check/ replace next? Thanks in advance for any tips.
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
The problem is the control panel. You may have to shut the power off for a few seconds to reset the control board, then check to see if it works. If not, the control board has a break in the wiring or the keypad is no good.
SOURCE: Dishwasher stopped with water in the bottom.
Hi Gordon136,
I believe your Drain Pump is causing the problem, it may have a leak on it, I'd suggest removing the Drain Pump from the lower sump - Accessable from the bottom of the machine. Another component to check is the Circulation Pump - Look for water marks on both the Drain pump and Circulation pump.
If any of the 2 are down to earth then the power would trip, or in your case the fuse would pop.
I doubt it is anything to do with the control Panel, the reason why I am saying this is that your water is still in the machine, your dishwasher will activate the pump to drain it, but it would then send power through to it. Then cause a dead short and POP goes the fuse.
Hope I have described this in a way you can understand.
Please let me know?
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please accept it
