When I turn on the camera, it keeps saying busy. I tried turning on and off. When I try to look at the menu none of the buttons will work. How do I reset it?
SOURCE: canon rebel xt
If you are using the camera software then remove it and Windows do the Work. If are sill having trouble, Then invest in a USB card reader.
SOURCE: Canon Digital Rebel XT / EOS
In the communications option of the camera Menu, there are two options to choose from. Try changing the options. one of them works with Canon software to download images.
SOURCE: Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
SOURCE: Unable to import photos from Rebel XT to iphoto on mac..."busy"
Try changing the "communication" setting on the camera from "PC Computer" to "PTP"
Menu > Tools2 (wrench/hammer/2)
Communication = Print/PTP
http://docs.info.apple.com/article.html?artnum=75336
SOURCE: can't get pictures onto computer
Menu > Tools2 (wrench/hammer/2) Communication = Print/PTP
