I have a new Onn tv and need the tv code to have my bell expressvu remote work with this tv
Posted by Carol Martin on
    Top Expert:
  • Televison & ... Master
  • 76,455 Answers
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Posted on Mar 19, 2013
5 Related Answers
Anonymous
SOURCE: Replacement remote for bell expressvu
Here is the link to pdf document: http://www.highspeedsat.com/pdf/satellite-tv/expressvu/remote.pdf
Posted on Sep 30, 2008
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Posted on Jan 28, 2009
Anonymous
  • 56 Answers
SOURCE: bought a dish identical remote to Bell Expressvu.
You may need to program to your equipment, go to dishnetwork.com/tech and that will show you how to address your remote.
Posted on Nov 12, 2009
BeckiB_DISH
Becki Barned
  • 286 Answers
SOURCE: old bell expressvu remote and i cant syncronize it
Hello!! There are a few ways to get this working to shut off the TV. I put some instructions at the bottom here. These are instructions for a power scan, which scans the TV for the correct code.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Posted on Mar 01, 2011
raycalo
Ray Calo
  • 358 Answers
SOURCE: i need a code number
I have provided instructions on programming the remote to your Dynex TV. I have included the codes for your TV. We do not have codes for the Universal remote. You need to contact Phillips to see if they have codes that you can use. I hope this helps.
Address remote to TV:
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote codes: 720, 115, 969, 111
Ray Calo
DISH Network
Posted on Apr 13, 2011
What code do I use to have my onn tv work on my bell expressvu remote
001,000,003,008,028,018,037. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 18, 2013 | Televison & Video
I need a code number for a DAENYX TV ihave a remote philips brand number sru5107/27 All so will the remote for bell expressvu work for for HD expressvu the remote belongs to model 3200 express vu
Ray Calo
DISH Network
Apr 12, 2011 | DISH Network IR Remote Control
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Mar 09, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Need remote code for programming a bell expressvu receiver
JVC DVD 0558, 0623
Regards,
VOTIT
Jan 27, 2009 | Jensen 143307 Remote Control
Feb 14, 2008 | DISH Network IR Remote Control
6419ctb how to use av inputs
i needs the codes for the tv please
Jan 01, 2008 | Sylvania 6419TC 19" TV
Program bell expressvu remote for new tv
The easiest way is to do device code scan. Since you want to program the TV, hold the TV button on your bell expressvu remote. When all the top buttons light up, press the power button, the TV button light should remain lit. Keep pressing up/down until your TV turns off. When your TV turns off, press the # button. Thats all. Your done.
If you want to set up the AUX button, hold the AUX button until all the buttons light up. Then press * and either
0 - second TV
1 - second VCR/DVD player
2 - audio amplifier or cable box
Then press the power button and press up/down until the device turns off. The last step is to press # and your done.
Oct 22, 2007 | Televison & Video
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
