This is the first time I've needed to change the cartridges.
Please follow the link will show how to change :
http://www8.hp.com/h20621/video-gallery/us/en/customer-care/printers-and-all-in-ones/replace-ink-and-toner/1655134310001/replacing-a-cartridge---hp-photosmart-7510-e-all-in-one-printer-c311a/video/
Mohamed Hejazi
HP TECH. SUPPORT
Afaqnama - Tripoli - Libya
SOURCE: HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
SOURCE: my HP J6480 printer will not recognize the ink
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
SOURCE: Have HP F4480 printer, replaced
Welcome to Fixya. If you have a paper jam error message you can use the link below and follow the steps on how to clear paper jam error. Sometime you just need to clean the rollers and it will be fixed.
HP F4480 Paper Jam Fix
If you have questions please let me know. Thanks for using Fixya
SOURCE: Have HP Photosmart C5180 printer.
This will be very helpful to you http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpa02060
SOURCE: printer claims ink cartridge is expired and won't let me print
Hello, if you change the date on your computer to 3 months previous (say), then reboot, you can probably overcome this temporarily. Obviously, for normal operation it's best to restore the date to current, and only set the date back when you want to print something.Regards,nicam49
