This answer relates to keyboard hardware issue only.
On powering on PC look for keyboard lights flashing. If no flash. Power down. Remove/replace kbd plug. If still no flash of lights then please read on.
If kbd is old ps/2 type. Which is small round, sometimes purple, plug. Ensure its not in not in the similar mouse socket. Check for bent pin in plug. ps/2 sockets can fail (as can keyboards) If no joy and no other ps/2 keyboard works, consider replacing with usb type.
If kbd is usb type, do power off/on look for lights flashing. If no flash of lights, try in different usb port. Try replacing keyboard.
Hi, I dont have a ps3 myself, but sometimes when I play at my friend's house, this happens when u got more than 4 controllers on, like the ones from gh/rockband.
Press and hold the ps button, it should get u to the screen where u can chose to turn off the system, turn off the controller or change the controller number, just put it in number 1 to 4, and should work fine.
I got mine to work! Mine is the th8110u1003 and although the screen seemed to display, it was completely unresponsive to touch. Long story short, there is a flat watch battery behind the screen. Get to that and remove it for 15 seconds and reassemble. It powered right back up!
i had the same problem but my problem was the touch wasnt working!!! inside the screen case there is a tiny black square it has summat 2 do with tht coz my touch stpd working and it was all coz of tht!!! i had 2 buy a new cover 4 my fone it also powers tha buttons so i wud get a new case ( ps.... not a protective case!! lol an actual body of it lol) hope i helped
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal.
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!
rating if the solution I provided fixed or helped you resolve your problem.
Even with the tv turned off, the power supply is still active.It's supplying voltages to the microcontroler, that's why each time you press the power button on remote the tv respond by turning on. First check the power cord to be well connected in the power-bar and if it's ok...well the power supply is defective and due to the high risk of electric shock i suggest you to call a technicien.
P.S. I respond here because I don't know why our chat session got disconected.
use a paperclip and manually eject the disc....recycle the unit, power it off then wait then power it back on and it should be seen be available again i hope this works for you
ps put paperclip into tiny hole in front of disc drive....thx
