SOURCE: I have a maytag top loading washer. I have a F51
F51 means you have a rotery positioning sensor error or (RPS sensor) This is clipped onto the top of the stater motor and means you will have to replace the RPS sensor if the tub is spinning smoothly by hand.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: iam haveing a error code of f51 on my maytag
There are two possible causes of this code an unbalanced load can cause this error, The unit usually tries a few times to redistribute the load before it will display this error. Try another load if the error occurs then you have bigger problems. The other cause could be a bad rotary position sensor on the motor in which case you would probably want to call a tech.
Hope this helps _MJ_
SOURCE: I have a Maytag Bravo
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I have an F51 code
If you are handy, yes. The rps sensor is mounted to the motor. Remove power and tip the unit back. The motor has one bolt in the middle that holds it in place. Once the motor drops out the sensor clips off the stator motor.
First time will take you two hours or so. Not difficult time consuming though.
SOURCE: Maytag washer -- what does
hello, you need to install part #W10183157. it comes with instructions itnot that hard to install. it should correct your issue. thanks and please rate me :)
