I used gel detergent and now it won't wash. How do I fix this?
It is very likely the two problems are not linked. Use small quantities of power detergent (Finish works best) to avoid foaming. The foaming usually triggers flood switch and shuts dishwasher. If the beeping is constant then most likely the flood switch is triggered. But if you get one or 2 beeps when you press start, then it is likely some sensor in drawer is faulty. Usually the drawer close switch is not working.
SOURCE: Fisher paykel DD603 top drawer starts cycle then
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
SOURCE: Kitchenaid 2 drawer dishwasher beeping
its saying its flooded allow a few days and it will go away then fill and drain then fill and drain till all soap is gone
SOURCE: Fisher & Paykel Dishwasher DW60CSX1
I have a dishwasher - "Soft Touch" which seems to be stuck on F1. This occured in the middle of the night and although turning off at wall cannot get it off this setting
