Need to completely defrost freezer. hot rags, hot water, paper towels, etc. Until you get all the ice out you don't have a chance of unclogging the drain. Could be just ice clogging it too which in that case hot water will solve that as well. If it's something else clogging the drain, I've used a mini bottle brush to unclog them or even a stiff piece of solid wire.
SOURCE: Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
SOURCE: water leaking inside of refrigerator from freezer
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down. Problem solved.
SOURCE: water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
SOURCE: Ice maker is leaking water and making ice cycles in the freezer.
the unit need to be replace some time its start leak and the only solution is to get a new one unless something got stuck in it and the water just coming out...the part# is 2198597 i think and it is 160$ at sears parts
www.911servicetoday.com
