Hello, I bought the headphone one year ago (through amazon in France), and today it won't turn ON. When charging, the red LED is ON. At the end of the charging, the green LED is ON. But when I press the multi-function button, even for 1 min, nothing happens (no green or blue LED blinking). I live in Ethiopia, and there is no reliable repair shop there. Is there something that I could do to solve this problem? Thanks in advance for your help,
SOURCE: AKG K240S headphones not working well.
A buzz in one ear and no sound in the other 'sounds' like an open connection inside the headphones. The K240-series uses three wires from the pin to the headphones. Try this link to get wiring schematics and disassembly details: http://www.akg.com/site/powerslave,id,7,nodeid,7,_language,EN,cat,11.html
DHE 2008
Posted on Apr 25, 2008
SOURCE: Severed cord on my wonderful headhones AKG K24P.
It sounds like you actually have 2 wires closely wrapped together. They are very fine and you have to make sure that you have separated all of the wires from each other. Generally you will have a red wire and a copper colored wire for the right side and blue (or green) and copper colored for the left side. you need to make sure that none of these little wires are still mixed with each other, otherwise you have a dead short and the speaker will not work. The insulation is very thin so there is no need to strip it, the insulation will burn off when the solder is applied
Posted on Feb 21, 2009
SOURCE: Hallo! I have been using AKG IP 1 ( i have own
If you have an account on ebay.com,you can purchase it online. so goto www.ebay.com thanks
Posted on Oct 26, 2010
SOURCE: A year ago i bought
Hi,it might be due to the wire that has cut inside the speaker area.
You will need to open the speaker area, and check if the wires are still in place.
And also, if the wires are intact, You will need to replace the speaker inside the headphone, That will solve the problem..
Thanks for using fixya....
Posted on Oct 28, 2010
SOURCE: I bought my AKG K450
If you click my user name you will find a tip about headphones that might be able to help you.
Posted on Apr 22, 2011
