Samsung GALAXY Note Smartphone Unlocked Logo
Rod santos Posted on Mar 18, 2013
Samsung galaxy note 2 all outgoing voice calls are disabled- how to enabled it
All outgoing voice and video calls are disabled international calls-disabled
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 14, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
643
Points
I bought Samsung galaxy note 2. I can send SMS and receiving incoming call. But outgoing can't make it. Could you please tell me the reason and solution?
My phone is Samsung Galaxy J4 Plus. I accidentally on the fixed dialling number but I cannot turn off now because my PUK 2 was permanently blocked as I tried too many PIN codes.
Is it stolen? Bought in a pub? Found in the road? How can you not know your PIN Code?
PUK Codes can only be supplied by the Telco that owns the phone. There is NO OTHER WAY. Locked with a 128 bit RSA Encryption Code.
All about PUK Codes
https://www.fixya.com/support/r26056685-phone_asking_puk_code
Outgoing calls are restricted by FDN mode - YouTube
https://www.youtube.com > watch
PREVIEW
0:52 Outgoing calls are restricted by FDN mode on samsung galaxy mobile , how to disable /enable FDN mode.
YouTube · Ratan Mulewa · May 21, 2017
How to turn off the internal voice that tells me everything I am doing like I am blind galaxy Samsung
This feature is called "voice assistant" or "talk back." It can indeed be turned on or off. Below is a link offering visual depiction of the procedure.
Disable Talk Back Mode in Samsung Galaxy Tab VisiHow
How do I put a voice message on my phone when I am not available to take the call
Samsung Galaxy S6 Edge: How to put a voice message on phone when not available to take call:
Hello. If you did not set up your voicemail account yet..
Simply, on your S6 call your own phone number. When you do this it will ask you to set up your outgoing voice message.
Setting up Visual Voicemail
Visual Voicemail Samsung Galaxy 6 edge G925T
1helpful
2answers
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
1helpful
My outgoing calls are barred how to deactivate it on my Samsung galaxy s duos
  1. Go to Apps through Home screen.
  2. Tap Phone.
  3. Tap the Menu key.
  4. On pop up menu select Call settings.
  5. Tap Additional settings.
  6. Tap Call barring.
  7. Tap Voice call.
  8. To disable call barring, tap each of the barrings types that you've enabled before.
  9. Enter your barring password. When you never change your barring password, then the default is 0000.
5helpful
How do i unlock my pattern lock on my galaxy s2
1. try entering null as password.2. try entering your username without @gmail.com3. Combine 1 and 24. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.6. Try the normal recover password routine from GMail.com
7. Perform a factory reset. YOU WILL LOOSE all not-synced DATA (SD card will be left untouched).
1-6 are possible workarounds, these doesn't work for everyone but can be worth a try to avoid factory reset. 6. is what should work but hardly never does. 7 - The factory reset always work
Added reference with some additional info, how to factory reset can be found there.Good luck!
2helpful
2answers
I cannot find my samsung t404g's voice recorder and I would really like to use it but I also cannot find my manual: HELP
Hello.
You can view and download the manual by clicking here:
T404g
1. In Idle mode, press Menu ? Games & Apps ? Voice Recorder.
2. Press the Record soft key to begin recording.
3. Record a memo by speaking into the phone's microphone.
The display simultaneously shows the elapsed time and the total
time allowed.
4. Press the Stop soft key when you are finished recording.
Please rate my answer.
Aug 05, 2011 • Cell Phones
8helpful
2answers
Codes
Samsung Secret Codes
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
