Zanussi WJD1257W Front Load Washer Logo
Question about Zanussi WJD1257W Front Load Washer
How to change Zanussi drum bearings
5 Related Answers
Anonymous
  • 183 Answers
SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Posted on Aug 30, 2007
Anonymous
SOURCE: Zanussi FJS1197 w ashing machine making knocking noises when spinning
I posted the question originally. Are you sure the back panel of the machine doesn't have to come off ??
How about the front ? What tools will be required
Posted on Jan 03, 2008
Anonymous
  • 54 Answers
SOURCE: Zanussi FJS 1197W washing machine main bearing
sorry you will need to remove drum
Posted on Feb 14, 2008
Anonymous
  • 44 Answers
SOURCE: replace washing machine bearings
It is a very involved process with the tank having to be extracted form chassis. There is really no step by step instructions for this, but most reports say it is not economical to do this yourself. There may even be restrictions in your zip code. You should hire a technition to do this and the job takes about 2 hours.
I hope I was able to fixya problem and I wish you the best with this.
Posted on Oct 19, 2008
andy421
  • 57 Answers
SOURCE: noisey drum, can bearings be replaced on zanussi zwf 1421 w
Yes they can. Search for a service manual for instructions, on the net. Parts are not usually exspensive, Repairmen are. I did mine in less than an hour.
Andy
Posted on Nov 09, 2009
Replacing drum bearing on a ZANUSSI FJS 874 front loader ?
This is not a simple job, it can be fine but requires the complete disassembly of the machine to change the bearings, there are 2 bearings and a seal that require replacement, I can assist in guiding if you wish to do so, it takes around 3 hours total to strip and rebuild.
Noisy drum, grinding sounds when the drum is spinning
Hi
The grinding sound is because of damaged or broken bearings.
You will have to see if the motor rotor bearing is damaged or the drum bearing before you change anything.
Regards
Berry
8helpful
2answers
Drum noisy when in high speed spin
Problem for Zanussi ZJD1219 Front Load All-in-One Washer / Dryer How do i change the main bearing please?
1helpful
Location of bearings on a zanussi fla100w
how do you change bearings on zanussi fla 1101W
3helpful
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • 1helpful
    Zanussi IZ12 bearings gone & plastic fragments in drum
    Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
    1helpful
    How do I change the drum bearings?
    The only 100% solution is to replace the whole rear tub half complete with bearings, you may also need to replace the drum shaft as well, because any slight wear on it will lead to premature falure of the bearings.
    2answers
    There is an answer at this link:
    http://www.howtomendit.com/answers.php?id=16357
    "some you can get at and some you have to lift over the top, when you get there you will need to smack the bearings out, maybe a old socket set with a long tube just to fit inside the bearing hole?. for what its worth go to the tip you might find one, that just wants a door seal?"
    You must have some technical experience.
    good luck!
    Zanussi aquacycle 1200
    May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
    Slim Jim
    Open Questions:
    See all Zanussi WJD1257W Front Load Washer Questions
    Top Zanussi Washing Machines Experts
    W.L.
    Marvin
    Marvin
    sheakhly
    Level 1 Expert
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
