I need the circuit diagram of the Rotel RA 12, can anybody tell me please
I think RA 12 is not existing type, but RA 12xx types exist.
Please try this link, and I hope you will find the relevant documentation.
gylacz
SOURCE: the two 5 amp fuse inside the amplifier keeps blowing
That must be the inrush current.
Maybe you are using the wrong fuses.
Please check if those are fast or slow types.
You need slow types.
Good luck,
Gerard
SOURCE: Rotel Amplifier RA-9808X
Instead of replacing you can try and clean it. There are a lot of good contact cleaners out there.
SOURCE: Are you able to provide a circuit diagram or even
I am sure I have fixed this model in the past. A lot of Rotel gear of this vintage, although sounding quite good, had been farmed out to Taiwan for manufacture. This was back in the day before electronics came from China. But the quality of the build was often low grade, and hand assembled with custom made IC's and transistor arrays that are no longer available due to local manufacture(taiwan). Some gear was Japanese and better build quality. Look for a 5 legged transistor (small black bodied device) device, or blackening of the legs of any transistors(black death i call it).Is it possible to post an in focus picture pof the internals to jog my memory on this amp.
SOURCE: Manual circuit diagram
I don't believe that Rotel service manuals are available outside of authorized service centers. Can you provide us with the problem that you have? Perhaps we can guide you through the repair.
Thanks,
Dan
