I've tried unplugging the printer from power and from the computer and I've restarted the printer. I cannot however restart my computer at this time because I have to print the results of a test that I really don't want to take over and cannot save the results.
SOURCE: job won't cancel
if I was you I would uninstall the driver and install everything from scratch.That should solve the problem
SOURCE: Printer 966. Deleting Print Job stuck in Que
Sounds like a problem with the spooler.
Try to bypass the spooler when printing by right clicking on your printer and select "properties"
Select the "advanced" tab and select "print directly to the printer".
Hoepfully this should take care of it.
SOURCE: My dell 948 is not communicating with my computer,
Try to uninstall you printer driver and restart your computer. After that install your printer software now it works.
SOURCE: We are getting error code 004-332 Restart Printer
Hi
This error code on Dell 3100CN occurs when toner cartridges are not seated properly and/or are not properly locked in. Turn off the printer and unplug it. Now, you need to open the front door and pull out the drum. Try moving the carousel and check if it moves freely. While moving the carousel back and forth try adjusting the cartridges. try to unlock the cartridges and lock them again.
Now turn off the printer and turn it on after 1-2 min.s.
Daniel Scott
SOURCE: My Dell V505 printer won't
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
