SOURCE: Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
SOURCE: My GE smartwater hot water heater has no pressure.
try to open and close the valve at the unit,this shut off valve may have gone bad,replace it this may help.
SOURCE: GE smartwater filter (model GXRLQR) stopped working...help!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
SOURCE: I don't have a problem, just a question. I
Check the time of day, and make sure it's accuate. Reset if necessary. Add salt if it's low. It's always best to let the salt level run low (about 1-2") so it doesn't mush. Only add 80-100 lbs at a time for best results. This particular softener doesn't keep a water level in the tank, so you won't see any water in the salt area. If there is standing water in the salt area, that could mean it's not working the way it should. Here is a link to the owners manual. It's in PDF format
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003674144.PDF
SOURCE: I have a GE smartwater reverse osmosis system
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
