Good evening, tonight I decided to adjust my watch and after some time I noticed that "everything" seems to be twisted about 2 hours. For instance: when I put the "stopwatch" it is not on the 12' but it is on 10.
SOURCE: Casio Wave Captor Watch wont set to correct time.
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
SOURCE: Problem with the time setting
The only info which continually flashes is a dart and the letters chg
SOURCE: How can I adjust time for Baby-G MSG-5000
Opne the following page and input "5002" into the text box.
http://world.casio.com/wat/download/en/manual/
And see chapter 8 of "Configuring Home City Settings" in the manual.
SOURCE: the watch has an alarm that goes off at 10:17 pm,
Go to the casio web site "www.casio.com/support"
select "manuals"
Select "watches"
Select "watch manuals archives"
Enter details of you watch and download instructions.
SOURCE: Module 3070 - PAW1300 >
Hi, Obviously you need to roll the time 12 hours ahead. If the watch doesn't receive the Atomic signal properly at first, go to page three of your manual, and try doing it manually following the detailed procedures there.
If you don't have the manual, get it here:
Take the four-digit (3070) module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
