The screen has a green haze and it is green where it should be black.
SOURCE: My tv is a sanyo ds31590. I need to connect to an
you would need to connect it using rca to vga cable
because this tv only supports s-video and rca
and your laptop only send outpuy video in hdmi and vga
co to any radio shack or similar and ask for that kind of cable
SOURCE: acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Still no luck with the green screen. I have replaced the cable to the screen and made sure all connections were tight and none of the pins are bent. I have also replaced the screen with another screen from another laptop that is identical to the one with the green screen.
still looking for a solution for the green screen
