Question about Singer 8280 Mechanical Sewing Machine
Why do my feed dogs grap my material at the beginning of a stitch
The feed dogs grab the material and gathers the cloth at the beginning of sewing , they will not let the material move to sew a automatic button hole.
Posted by edith adkins on
Debbi's Sewing Machine Repair
  • Singer Master
  • 7,365 Answers
Some sewing machines have what is called a buttonhole lever that
is to the left of the needle that has to be pulled down before the
machine will make a buttonhole,here is a link for a free manual
if you dont' have one
http://www.singerco.com/uploads/download/430_8280_es.pdf
Posted on Mar 18, 2013
5 Related Answers
RickE1
Rick
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
Anonymous
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
Anonymous
SOURCE: How do you sew button holes?
I am assuming that you have marked where you want the button hole to be. Here is the link to the manual for the 5050.
446_5040_5050[1].pdf The instructions for making a buttonhole are on page 36
Posted on Apr 21, 2009
SOURCE: Frozen feed gears singer sewing
the machine needs to be checked when the feeddogs don't move
but first check to see if the feeddogs are in the up position & if the
feeddogs are up, then the machine needs to be checked
Posted on Apr 30, 2012
sylviaivie
  • 1564 Answers
SOURCE: Stitching keeps gathering while I'm sewing
#1 cause of puckering is a tension/threading problem. Make sure the thread/needle matches the fabric type too.
Posted on Dec 15, 2012
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
Feed dog button is stuck in the in position won't come out to raise feed dogs?
"FEED DOG BUTTON" ISN'T QUITE CLEAR. HOWEVER, THE FEED DOG IS CONTROLLED BY THE STITCH LENGTH. IF THE STITCH LENGTH IS SET TO ZERO THE FEED DOG WILL STAY BELOW THE PLATE AND THE MATERIAL WON'T MOVE.
Jan 31, 2016 | Sewing Machines
Brother CS6000i with setting 00 for straight line stitch is making a left curve stitches instead going straight.
***Your feed dog under the pressure foot seems to be pulling on one side a little harder which indicates wear. It is likely to solve the problem by replacing the feed dog.
***Before you do this try to lower the pressure on the pressure foot. If the material you are sewing is thick it will have an effect on the pull of the feed dogs. The material you are sewing that you sent appears to be jeans material. It looks like it is thick and somewhat slippery.
Oct 05, 2015 | Brother Sewing Machines
Material doesn't feed
Are your feed dogs down? If not check your stitch length or possibly it is set to tack stitch. What material are you trying to sew? If it is lightweight like tulle you will have to set your feed dogs. Check your manual on how to do this.
Mar 10, 2015 | Singer Sewing Machines
Dog feet seem as if they are not raising high enough to grab material and move it back. It their a simple adjustment?
It could be that your stitch length is not long enough to sew in a forward direction. Embroidery/Sewing machines have a feed dog switch to raise and lower for sewing or embroidery.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 28, 2014 | Sewing Machines
The feed dog moves, but doesn't seem to move the material through
try adjusting the bar that the presser foot is attached to , check in your manual for the instructions to do the adjustment..
Jan 24, 2014 | White Sewing 1418 Mechanical Sewing...
My bernina 1030 won't feed material
Make sure the feed dogs are in the raised position and that the presser foot has been lowered before beginning to stitch.
Feb 11, 2013 | Sewing Machines
Thread bunches up from bobbin feed.
Remove the needle plate and clean the feed dogs there could be fluff gathering.
Check your needle is not damaged.
May 30, 2009 | Singer 1120 Mechanical Sewing Machine
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Singer 8280 Mechanical Sewing Machine Logo
87 people viewed this question
Top Singer Sewing Machines Experts
Irene Tulloch
Chris Wetmore
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
