The washing machine turned on and started the cycle, but then tripped the fuse and turned off. Even though I've fixed the fuse and the plug is working (have confirmed by plugging in other appliances), the washing machine won't turn on again and has trapped my clothes inside with a locked door. Any ideas how to fix it?
SOURCE: Door locked
sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
SOURCE: indesit W1A111 starts cycle when selector set to "off"
hi i need a user manual for this machine. Where could i get one please. x
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
SOURCE: Hi I have broken the door
i saw same problem in another brand and it was easy it just open the small door of drain filer then open the filter slowly the water will out into sure small pan under this place you putted then we pull asmall plastic ring hang to ...... open the lock door then enjoy smell .. try this maybe it help .... i try to catch any infomation to you for this m/c but i did not found... thank you
SOURCE: my indesit washing machine door wont open
have you tried unplugging it for a couple of minutes ?
