Question about Mitsubishi VS-50605 50" Rear Projection Television
Stuck in thearter mode - Mitsubishi VS-50605 50" Rear Projection Television
Posted by listitwithmo on
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Bill
Dec 07, 2007 | Televison & Video
My lg arx8000 home thearter is not playing files from my external hard drive
Probably a format issue.
Not enough info
It's like saying My car won't start and not saying the gas gauage reads empty.
Apr 01, 2014 | Western Digital My Book Essential Edition...
Mitsubishi ws 5074 does it have a reset button im stuck in thearter mode dont have remote with cancel button on it any way to get back to factory settings
On your remote hit home or menu then 1 2 3. this brings up the reset menu. Hit enter and the tv will reset to new out of box condition.
Mar 19, 2013 | Televison & Video
How do i get normal television sound to come out the sarround sound
basically you would use rca cable from back of tv it will say audio out plug that into tv input on home thearter and there you go swtich home thearter input to tv and there you go also new lcd tv only come with a digital out for audio in that case your home thearter will need a digital input or you would have to buy a converter to convert digital audio output to analog aka rca plugs it cost about 50 bucks fora descent one
Aug 27, 2010 | Panasonic Home Theater System System
Where can i get a new remote? mine is MIA and the system is almost useless with out it for my kawasaki 5 dics dvd home thearter system.
Try Ebay with your model number in the search. You may have to search a few times over a few days to see what new items are listed.
Jan 16, 2010 | kawasaki 5-DVD Home Theater System - 1152...
PIP is causing problems
You are lucky in that this is problem you can solve yourself with a little diligence. The set has defaulted to the 'Theater Mode'. It happens frequently with this model. It is merely a setting in the customer menu. Go into either SETUP or ADVANCED SETTINGS and look for something refering to 'Thearter Mode' and turn it off. An owners manual would help locate it.
Sep 01, 2008 | Mitsubishi VS-50604 50" Rear Projection...
Speakers for home thearter
Hi dogbert007,
Luckily, shielding your TV from the magnetic field produced by audio components is necessary due to the technology in a Cathode Ray Tube (CRT) display. If you have an LCD television, you should not have to worry about placing them within a few feet as you plan.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 10, 2008 | Televison & Video
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
