Question about Sony Walkman NWZ-E344 Digital Media Player
Replacement power supply for Sony Digital Media Player Model NWZ-E344
Where can I purchase a replacement power supply for my Sony Digital Media Player Model NWZ-E344?
Posted by connieric884 on
dadodadman
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
All you need to know is how poerful your computer is, that is find out how much power the equipment installed is using, then you can replace the power supply with one that meets the computer needs.
Make sure of the type of power supply connector you have Atx etc.
You can go with any brand, so as long as it's the correct connector type, and it has enough power to run your system.Things to note is the manufacturer of your graphic card, and the processor type, as they have different power requirements, graphic cards are usually the most demanding.
Posted on Mar 17, 2013
3 Related Answers
Anonymous
  • 1456 Answers
SOURCE: my pc does not regonize
Hi there
Remove the MP3 player, wait at least 10 seconds and plug it back in. Do this multiple times. It may connect after a couple of tries. If not, continue by opening the device manager.
Open the Start menu search box and type "Device Manager." Chose it from the list of available options.
Locate the device by searching for a yellow exclamation point. If you do not see it, click to expand "Universal Serial Bus Controllers."
Choose the player from the list and right-click it.
Click "Uninstall." Click "OK" to restart when prompted. If there is no change, try again, this time placing a check by "Delete the driver software for this device." This option might require you to reinstall the drivers, so don't try this unless you have the disc handy.
Plug in the media player after the restart. You should see a message stating the device is connected and ready to use. If this fails, visit the website for the manufacturer of the MP3 player to see if there is a firmware or driver update. Install the update according to the instructions and the player will work.
Posted on Sep 02, 2010
YourZEN
YourZEN
  • 820 Answers
SOURCE: WHICH FORMAT OF VIDEO DOES Sony NWZ-E436f Digital
Online support for NWZ-E436F on next site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=NWZE436F&LOC=3
Manual:
http://www.docs.sony.com/release/NWZE435F_436F_438F.pdf
page 118 showing all the supported file formats
see also page 9 for the software to be used for transfers
Posted on Oct 23, 2009
  • 102366 Answers
SOURCE: How do I get a
http://esupport.sony.com/US/perl/model-documents.pl?mdl=NWZE344&LOC=3
Posted on Jan 22, 2011
Where can I purchase a replacement power supply fo my Sony Digital Media Player Model NWZ-E344?
Check out newegg.com they often have a wide array of power supplies at a reasonable cost for sell.
Make sure of the power supply watts and the connector type, once you have those two things search the site for a replacement.
Remember to do an internet search for discounts or coupons, as you can sometimes find codes to enter on newegg to get a discount.
1helpful
What keys need to press to cancel hold function?
Sony NWZ-E344 has hold switch on right side, slid hold switch to cancel hold function.
Let me know if model number of mp3 player is different to provide you revised info.
Thanks.
How do i add photos to my nwz-e344
Connect the Sony Walkman NWZ-E344 (8 GB) Digital Media player to your computer using the device's USB sync cable. Wait until your computer detects the MP3 player.
Click the "Start" icon in the taskbar. Click "My Computer."
Double-click "Removable Disk." This will open the root storage directory of your MP3 player, which is where all its files are stored. Locate the "Photos" folder inside this directory.
Drag-and-drop pictures from your computer into the Sony Walkman NWZ-E344 (8 GB) Digital Media player Photos folder: Click on a picture file and hold down the mouse button while moving the file to the Photos folder, then release the mouse button to copy the picture to the folder. You can now view these pictures on your Sony Walkman NWZ-E344 (8 GB) Digital Media player.
If your Sony Walkman NWZ-E344 (8 GB) Digital Media player does not support photo viewing, you can still add pictures to the device. Drag-and-drop the pictures anywhere within the root storage directory. You can transfer the pictures to another computer or any USB-compatible device.
Good luck.
2helpful
I need the manual for sony walkman nwz e344
My Sony Walkman NWZ-E344 won't turn on but when I look at the properties it says it is at 70% charge
This is how i made mines work:
http://esupport.sony.com/CA/p/model-home.pl?mdl=NWZE344&template_id=1&region_id=3&tab=download#/downloadTab
go to the link, will lead you to Sony eSuppot - Driver and software , download firmware update, remember to keep your Sony NWZ-E344 plugged into your computer and clicked the reset button while its plugged into the computer before starting this, this worked for me, hopefully it also works for you :)
1helpful
Lost instructional information for new mp3 player
If it is Sony NWZ-E344 mp3 then click Sony Support to download copy of user manual.
And if it is some thing else, let me know exact model and brand.
Sony Walkman NWZ-E344 Digital Media Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
