Question about AT&T Cell Phones
How do you reset a locked 3.2 megapixel
I forgot my google account. And i forgot my pattern.
Posted by Dee Flamee on
Candace Patterson
    New Friend:
  • 17 Answers
Reset your phone completely to a Factory Reset
Posted on Mar 19, 2013
5 Related Answers
ib_yang
Ivy Cada
  • 1098 Answers
SOURCE: i have a samsung galaxy
The way around this is to factory reset the phone.
1. switch off. Hold volume UP and power button and home button simultaneously. release home button (and press again) while still holding volume up and power button. A boot up screen will pop up. Use volume keys to select (reset and restore) press home button to select.
2.Once reset and the phone starts up again it will still show locked. Get another phone to call your phone. as soon as you swipe answer press back key (arrow key) (you gotta be quick) and the main home screen will come up . press the left menu button and select settings and turn off pattern code then go to menu and factory reset the phone again.
Hope this helps.
Posted on Feb 24, 2011
ishaqazmi
Ishaq Azmi
  • 80 Answers
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it. samsung_i9000_galaxy_s_hard_reset.png
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
Posted on Oct 17, 2010
ismael castillo
  • 318 Answers
SOURCE: pattern lock on sony ericsson xperia x10i need
*Turn off the phone
*take off battery & put back in
*press and hold down the right & left silver buttons just under the screen
*with stylus press in the hole on the right side of battery
*after 10Sec you will be prompted to press the R key
*If successful press the space key to finalize changes
www.usedcellphoneshop.com
Posted on May 25, 2010
RONALD CARTER JR
  • 438 Answers
SOURCE: I locked my Kyocera Zio
Hi ashleysmi298 go on your computer and sign in to google. Under settings go to forgot password. You need to get you gmail password. If you don't remember the only other way is to do a hard reset on the phone. But here is the bad news , You will lost all your information and settings apps and whatever else you have on the phone, Now by going to google you can get your password and user name back. If that doesn't work you will need to powwer the phone off. hold the power and the up and down voule button at the same time. You do this until t comes on the screen.Now make sure you take out your memory card . If you don't want to do any of this go to your local carrier and have them help you with the hard reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Posted on Dec 10, 2010
matt-luvin-c
SOURCE: i hav a lg gt540 then i put a pattern to lock my
hold volume up with home button and search button and it will do factory reset but take any memory cards out first it works because it happened to my phone
[email protected]
Posted on Feb 01, 2011
How i can unlock my pattern of sony st21i
You need to have a registered Google account on your phone in order to reset the screen unlock pattern. In case you do not have a registered Google account, You must repair the phone software before tapping "Forgot pattern". The phone is locked if the incorrect screen unlock pattern was entered fives times in a row.
Follow the procedure below to repair the phone software:
> Open PC Companion 2.0 on the computer, tap Start then Repair in the "Support zone" application and follow the instruction you see on the screen. Please note that all personal data stored will be lost and the installed software on your device will be replaced. In case it is not possible to repair the phone software, contact your Sony Customer Support.
If ever you entered the incorrect screen unlock pattern five times, tap "Forgot pattern" then tap "Answer question" then tap "Next" and enter your answer for the security question. Next, tap "Unlock".
To reset it using your registered Google account, tap "Enter Google accounts details" then tap "Next". Tap the "Username" then enter the registered Google account username. Next, tap "Password" to enter the registered Google account password then tap "Unlock".
Oct 18, 2014 | Cell Phones
My grand daughter put a pattern pass word in my tablet and forgot the pattern
Continue trying different patterns until the unit asks for your google account sign in. If you have a google account go ahead and sign in. If you don't have a google account type null for the user name and four zeros, ie, 0000 for the password.
Jul 11, 2014 | Polaroid Tablets & eReaders
Forgot security pattern
When you forget your security pattern, you will usually be given the option to sign in into a Google account or any other account instead of drawing the pattern by displaying the "forgot pattern?" option.
Aug 11, 2013 | Samsung Cell Phones
I forgot my screen unlock pattern what i do?
Reset the screen unlock pattern
If the incorrect screen unlock pattern is entered five times in a row, the phone is locked.
Note: In order to reset the screen unlock pattern you need to have a registered Google account on your phone. If you don't have a registered Google account on your phone, you must repair the phone software before tapping Forgot pattern.
To reset the screen unlock pattern by answering a security question:
  1. If entering the incorrect screen unlock pattern five times, wait for 30 seconds and then tap Forgot pattern?.
  2. Tap Answer question > Next.
  3. Enter the answer for the security question.
  4. Tap Unlock.
To reset the screen unlock pattern by entering Google account details:
  1. Tap Enter Google accounts details > Next.
  2. Tap the Username field and enter the phone registered Google account username.
  3. Tap the Password field and enter the phone registered Google account password.
  4. Tap Unlock.
To repair the phone software:
  1. On the computer: Open PC Companion 2.0.
  2. In the Support Zone application, click Start > Repair and follow the instructions on the screen.
Note: The installed software on your phone will be replaced, and all personal data stored will be lost.
Tip: If it is not possible to repair the phone software, please contact your Sony Ericsson Customer support.
Jun 02, 2013 | Sony Ericsson XPERIA X10 Cell Phone
Forgot pattern lock android china tablet
ihave a china android tab and it is now pattern locked
Dec 27, 2012 | Tablets & eReaders
I forgot pattern for my LG MS690 phone and dont know google account
google has your information,enter and contact them for to provide your personal profile.
sincerly. God bless you
May 09, 2012 | LG Optimus M Ms690 Metro Pcs silver Fair...
How to unlock samsung galaxy y (GT-S5360).to many pattern attemps
I forget my unlock pattern code and now asking the gmail addres
Oct 28, 2011 | Samsung Galaxy S GTI9000 Smartphone
My lg ms690 is locked and I forgot the pattern code and my google account how can I get to reset or unlock
I forgot my pattern and my google account info could u help unlock or find google account info
Jun 14, 2011 | LG Cell Phones
I forgot the pattern of my cellphone and i also forgot the answer to the security question
If you forgot the pattern and the security question answer, you can also override it with the google account that the lock pattern requests.
The Google account that the pattern lock requests will be the same Google account you have used to access the Android Market and other Google apps on the handset. If you cannot remember these details, you would need to reset the handset using the Update Service program.
This program resets the handset while the phone is completely powered off so there will be no need to use the touchscreen or access the phone at any stage. You can download the Update Service here:
www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax8
Jun 06, 2011 | Sony Ericsson X8 Cell Phone
Unlock with google email
To unlock the pattern screen lock, sign in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. The user need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
Hope this help
Feb 17, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Cell Phones Logo
839 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
