Question about Spectroniq PLTV3250 32 in. LCD TV
Hdmi shows invalid mode - Spectroniq PLTV3250 32 in. LCD TV
Cannot access TV. Screen shows HDMI 1. Invalid format.
Is it possible that whatever you have plugged into HDMI 1 requires a firmware update ? for example a dvd player etc
Or perhaps the tv cannot handle the resolution if this is the case you will want to set it at what the computer manual states what it can handle with HDMI
If not perhaps Unplug the tv for a few minutes, and then let it boot back up and trying your hdmi inputs again. This should reset the microprocessor.
Best of luck :)
Nov 09, 2016 | Televison & Video
Invalid format on hdmi
Unplug set, HDMI, and a box if used for a while--connect the HDMI first and then power to set and or box--see if set will reboot or box.
HDMI does not like power loss, being connected or disconnected with power on etc.
Also in set menu make sure HDMI input is "available".
Apr 29, 2012 | Olevia Televison & Video
When I connect the HDMI cord from the ps3 to the t.v. is say's invalid mode.
you need to go into your ps3 settings and pick HDMI.
unless you did that and your tv is not 1.3 HDMI (that is the version of the software that speaks to your tv from ps3)
Dec 14, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
FPD1530 (Black) 15 in. Flat Panel LCD Monitor: Screen shows, 'Invalid Mode', followed on next lin...
It means your PC video resolution setting is too high for this monitor to display.
You need to set the resolution to 1024 x 768 @60Hz. Bootup in safe mode (hit f8 during bootup) select VGA support, rest the resolution to 1024 x 768 @60Hz, reboot.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
"invalid input" for hdmi
This model TV has specs for DVI, VGA, component video and S-video inputs. Are you using a DVI-HDMI cable? In that case, check your cable specs. DVI-I and DVI-D (single link and dual link) are not interchangeable and I would guess you have the wrong one connected to the HDMI for your unit.
I hope this helps.
Apr 12, 2010 | Olevia LT32HVM 32 in. LCD Television
My tv shows invalid mode when hooked to my
Active resolution of your tv is1280x720. You have to adjust the resolution in the graphic properties on your pc . Just keep tweaking it till you find one that works with your tv. I would start at max resolution (1280x720) then work my way down. Let me know what happens.
Apr 03, 2010 | Norcent Technologies LT-2720 27 in....
I have an LG 42LC2D TV with INVALID FORMAT ON HDMI2
I have had this same issue.
Problem your tv isnt true 1080p meaning it will not work however when you switch to componet cables goto menu then change the display settings to 720p or 1080i then your HDMI connection should work fine.
Dec 12, 2009 | Televison & Video
Invalid format
Use the power button on the front of the console, to put it in standby mode (red light on).
Then press and hold the power button until you hear two beeps.
This should fixya.... :)
please rate this answer!....
Sep 25, 2009 | LG Televison & Video
I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
Aug 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
DVI to HDMI problem please help
So have you found a solution to connecting your PS3 through the HDMI-to-DVI cable? I am also getting the "Invalid Mode".
Jan 14, 2008 | Sova DSV32P112 32 in. LCD Television
Spectroniq PLTV3250 32 in. LCD TV Logo
549 people viewed this question
Top Spectroniq Televison & Video Experts
Charles Tidwell
Al Ursich
Level 1 Expert
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
