Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
I have about fifteen RYOBI P103 batteries which when placed in the charger do exactly what they are supposed to do as far as the red light blinking and then the green light blinks for about 2 minutes and turns a solid green indicating a full charge but has no charge. What causes this?
christiaan saayman
    Habit-Forming:
    New Friend:
  • 129 Answers
Check output on transformer, 2 check pcb ,could be a regulator
Posted on Feb 23, 2018
5 Related Answers
Anonymous
SOURCE: Ryobi Model 1412001, 16vdc, 2A
I've open the charger and found that Q4 is open. But they have removed the part number from the component so you can't get a replacement.
Posted on Nov 02, 2007
joboo1
Jim London
  • 257 Answers
SOURCE: Ryobi 18V lithium battery won't charge
Hi, Thanks for getting back to me. The yellow and blinking red indicate a defective cell. Since it has lithium cells and is that new any repair to it would be a waste of your time. Ryobi tools purchased in 2008 have a 2 year warranty. I am guessing you probably got it at a home depot and you should return it under the warranty. All new Ryobi tools have a three year warranty. Good Luck! and Thanks for using fixya!
Posted on Feb 05, 2009
centurion_BB
Sam Smith
  • 83 Answers
SOURCE: Can I leave my Ryobi P113 charger with a P103
Yes you can that is an automatic charger when it is fully charged it shuts down the charging portion but keeps the charged light lit however this does not effect the battery.
Posted on Aug 13, 2009
Anonymous
SOURCE: ryobi battery charger with a solid yellow and solid green light
I was recently told that the lithium ion does not like cold temperatures so you may need to bring the batteries and charge into a warm location and wait until they reach a warm temperature and then charge them.
Posted on Jan 03, 2010
Anonymous
  • 111 Answers
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Posted on Mar 16, 2010
No light on charger when plug in battery to charge? Charger No. 1423701 with p103 battery. thanks
Two things come to mind (1) there is a short in the charger or (2) the light is simply out.
Oct 23, 2013 | Ryobi Multi-Volt Battery Charger
No light comes on my charger when i plug in my new p103 battery into charger no 1423701?
does the outlet work that the charger is plugged into... is the battery completely dead and the charger can't see it... is the charger even plugged in... or is it even any good ???
Is there a difference between the ryobi p103 lithium battery and the ryobi p106 lithium battery?
p103 is name of the battery. p106 is the kit with 2 p103 batteries. same thing just 2 times. the p104 however is bigger and holds more juice.
Jun 15, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Can I use the ryobi P110 charger with the P103 lithium-ion batteries ? Thank You
No. The P110 is for NiCad batteries. Any of the Li-Ion chargers like the P113 are backwards compatible and can charge either but do not try to charge Li_ion batteries in a NiCad or NiHi charger.
Dec 27, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Have a p103 battery that was in the p113 charger overnight and don't think it ever got out of the testing phase. The only difference was that the red light would flash about 5 or 6 times then stay on...
If you are sure your charger is working properly then your one battery may be shot.. i even had a new battery quit charging and had to replace it. they do not come cheap.
Apr 10, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Can I leave my Ryobi P113 charger with a P103 battery inserted in it for an indefinite amount of time with the charger plugged in, without doing damage to the battery or charger? Thank you. Phil
Aug 13, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
894 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Marvin
Marvin
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
