Question about DISH Network ViP722 DTV Receiver / 350-Hours Video Recorder
Dish remote 2 will not work all it does is turn on tv that's all.
I have called dish over and over it still doesn't work, it will turn tv on but not the receiver . Pls help
Posted by Frances Jefferson on
dish
  • Official Brand Answer
  • 263 Answers
Hello, Frances.
I can definitely provide some steps for you, and assist in getting this taken care of. I have listed the steps below to program the remote to your receiver. Make sure there are fresh batteries in the remote. Then take the TV2 remote to the main TV, and access the System Information screen.
From there, hold down the SAT button until all mode lights light up. Enter a number between 1 and 15 using the number pad on the remote. Press the pound (#) button. Once the SAT button blinks three times, press record. Test the remote and see if it works. If it's still having problems, let me know here!
Tommy Faust
DISH Social Media Representative
Posted on Mar 26, 2013
5 Related Answers
Jim Franks
  • 374 Answers
SOURCE: setting up remote 2
Ok lets assume you have the correct remote for the TV2 on a 322, you will need to take this remote to the TV1 location . Turn TV1 on and with the TV1 remote press menu-menu. You are now at the sytem info screen. Towards the bottom third of the screen you will see some wording that reads primary remote address and secondary remote address. Now with the TV2 remote press and hold the SAT button until all buttons across the top light up and release. The SAT button will be flashing. Now key in a two digit number between 1-17 that is unique to this remote only. Press the pound sign and the SAT button will flash three times. Now press the record button and the number you chose should now appear next to the TV2 icon. Are you good to go? If so exit out of all screens on TV1 and try thr TV2 remote at its location. You should be able to control the satellite now. If you can't ensure that the antenna on the back of the receiver is present and there are no obstructions in front of it. If you still are having issues - like you have to be at a certain point in the room- the remote antenna may need to be moved from the back of the receiver to the TV2 location Thanks for using Fix Ya.
Posted on Mar 18, 2009
Jim Franks
  • 374 Answers
SOURCE: I am attempting to control my Dish Network ViP 211
We can only offer codes for our remote. You will need to call Samsung at 1-800-SAMSUNG and get tthe code from them. Thanks for using Fix Ya.
Posted on Aug 16, 2009
Jim Franks
  • 374 Answers
SOURCE: Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Posted on Jan 11, 2010
Anonymous
  • 5 Answers
SOURCE: my dish 322 receiver wont work 2 tv,to get service
  • There are two satellite inputs on the back of a 322. There may be a single cable going to a splitter connected to these two ports or two individual cables.
  • If there are two cables swap them, if you still get signal on the same input only then the receivers input is dead.Otherwise follow the bad cable and ensure it is not damaged or disconnected. Swap the location on the other end and see if the issue stays on the same cable. If so replace the cable, if not replace the LNB or Switch.
  • If there is a splitter bypass it and connect the single cable directly to the input that does not work. If there is no signal the port is bad, replace the receiver. If there is signal then reconnect the splitter, press menu 6-1-1, check switch, and then test. Allow the test to finish. If the two inputs do not match replace the splitter... Its called a DP Seperator
Posted on Jan 31, 2010
Anonymous
  • 5 Answers
SOURCE: DISH DVR doesn't respond to remote
  1. If this is a TV2 location take the remote to the location of the DVR.
  2. Open the door on the right side of your receiver.
  3. Press SYS INFO.
  4. Press Record multiple times on your remote.
  5. Exit the screen and see if the remote works, if not replace the batteries and repeat steps 1-4
  6. If the remote still doesnt work, and this is a tv2 location (no receiver in the room with the tv) check the antenna on the back of your receiver, make sure that it is connected tightly and standing straight up.
  7. If none of this works call Dish and ask for a new remote.
Codes for tv remote for dish
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Dish TV remote control code list is given.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 16, 2014 | DISH Network Televison & Video
Sanyo Dp39843 can't get Dish remote to operate TV
I'd be happy to help to you with this. Please use the steps in this link to program the remote. http://www.mydish.com/support/program-to-tv-code-non-basic?WT.svl=leftnav Tory using codes 590, 683, 1113 or 720.
Apr 16, 2013 | Televison & Video
VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
Sep 01, 2012 | Vizio E470VA 47 in. HD-Ready LCD TV
How do i programe my dish remote to my Sanyo tv and to my dish reciever
The Dish TV remote control allows you to program the TV, VCR and DVD codes so that all you need is one remote. Most TVs can be programmed into the remote using specific codes in the Dish TV remote manual. But if you don't have a manual or list of codes, you can program the remote manually.
Instructions 1. Using Programming Codes
Find the TV code for your TV in the list from the Platinum Remote Control User's Guide (See References). For example, if you have a Kenwood TV, the three possible codes to try are 506, 573 and 712.
Press the "TV" button on the remote. Hold down the button until the "Sat," "VCR" and "Aux" buttons light up. Release the "TV" button and it will be flashing.
Enter the first code using the keypad. If you want the remote to control all functions on the TV, enter the code and press the # key. The "TV" button will flash three times.
Press the power button to turn off the TV and turn it back on again. If the code was correct, the TV will turn off and on. If the TV doesn't power down or back on, follow Step 6.
Try the next code from the list. Follow Steps 2 through 4 using each code until one turns off the TV.
2. Programming Without Codes
Press and release the "Power" button on the remote.
Press the arrow up key and stop. If the TV doesn't turn off, press the arrow up key again. Continue pressing the arrow up key until the TV turns off. Do not go fast when moving through the codes or you could miss the correct code. Press the arrow key and wait at least 20 seconds to see if the code works before pressing the arrow key again.
Press the # button on the remote control when the TV turns off ot lock the code.
For codes and more details, Visit this site for more details. The site name is (Electro-help). Just type in "electronicshelponline.blogspot" into the search box of your browser, and click search. You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and price. It is a blogspot site, in English Language
Jun 27, 2012 | Sanyo Televison & Video
TV 1 does not pick up Dish, scanned but doesn't show Dish
1) change the new batteries
2) Clean the contacts batteries very well
3) retight the springs contact for better contacts batteries
4) Open the remote and clean the keypad with special spray contacts cleaner.
Otherwise you must go to the repair shop.
download again the code: www. fitness.manualsonline.com
God bless you
May 23, 2012 | DISH Network IR Remote Control
Recent IR20.0 remote problem developed after 2 years without any issues. The remote no longer communicates to my 722k dvr reciever while my LG Tv is turned on. I have Hdmi run directly from reciever to my...
Hi Robert, my name is Cheri Torres and I work on the Social Media Team at DISH. It sounds like your remote is experiencing IR(Infrared) interference from your LG TV. You can resolve this issue by converting your TV1 remote to UHF(Ultra High Frequency) instead of IR. In order to do this you will need a UHF remote, the 20.0 remote is only an IR remote. Please email me directly at [email protected] with your account number or phone number on the account so that I can look into getting a UHF remote sent out. Thank you.
Cheri Torres
DISH L.L.C.
[email protected]
Apr 08, 2012 | DISH Network IR Remote Control
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I am trying to get my Dish Network to work on my Phillips HDTV. Dish Network told me that my television needs to be on channel 73 and when I try to put that channel in with the remote, the channel...
on your tv go to menu & somewhere there it will say scan for channels so it will scan for about 5 mins then grab your remote & turn to channel 73 & there you go . if not try moving the tv to a different source like AV or YDRB
Jun 23, 2011 | Cell Phones
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
DISH Network ViP722 DTV Receiver / 350-Hours Video Recorder Logo
163 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
