Question about Toshiba 32AF41 32" TV
Turn on closed caption without remote
I would need help on turning on closed caption on for Toshiba 27A42 27'' color t.v. I do not have remote control and menu options on television has everything except cc-on-off option.
How can I do. Also on my GE Universal Remote Control, I do not have option to switch on caption on t.v..
Regards,
JT
Posted by jt2140 on
1 Related Answer
pgh_pa_guy
  • 2992 Answers
SOURCE: I have a Toshiba 27AF45
Unfortunately, TVs don't always work with universal remotes. The original remote probably had a button to control the captions, and there may not be any other way to access those settings. If you can't find caption control settings using the on-screen menu, you are out of luck. The only options then are to try another brand or model of universal remote that may have a button which will work, or to locate a replacement original remote control.
Posted on Jun 21, 2011
I have a Sony KV-27ts27 television that I bought secondhand, without a remote. I need to know how to turn on closed captions. When I had cable service with AT&T Uverse, the closed captions were working but...
Here is a link to the manual. It appears to me your set does not support closed captioning. It is too old. It mentions channel captioning, but that is for a channel identifier for reference. http://diplo-best.com/314.php?k=ac30c98e172782467c3895e8cba613ad&ID=87078&q=SONY KV-27TS27
Oct 31, 2013 | Televison & Video
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Turning on closed captioning
If you have a cable box or a satellite receiver you will set up closed captioning on it. For most cable boxes you have to turn off the power and immediately press the menu button on the front or them. Then the hidden menu appears if you've pressed the menu button on the cable box itself and not on its remote soon enough. Then you scroll down to closed captioning and enable it. Turn the cable box back on to view your channels with closed captioning.
If you have satellite tv you can press one of the colored buttons on the remote to get to a menu that will allow you to enable closed captioning.
Dec 30, 2010 | Toshiba 40G300U TV
Lost remote, somehow child turned on closed caption without remote,how do I disable closed caption without remote?
Find a button on the tv manual control said Menu,press it. Goto tv menu find and turn off all CC1,2,3 and text 1,2,3.U should have no more closed caption.
Sep 12, 2010 | Philips Magnavox 20MS233S 20" TV
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
Cannot get closed caption
To view captions or text:
1. Select the desired program. Closed captioned programs are
usually marked in your local TV listing as “CC.”
2. Press CAP/TEXT on the remote repeatedly to select caption or text mode.
3. Press 1/2 on remote to select the caption or text channel.
4. To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen. I hope this helps. Thanks for using Fixya. Good luck
Nov 04, 2009 | Toshiba 20AF45 20" TV
How do i turn off the subtitles on my toshiba 36hf72 tv, without the remote
The subtitles in dubbed videos VCD/DVD the process to follow are :-
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and
sound effects of TV programs and videos that are closed
captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the
current program, such as weather or stock data (when provided
by individual stations).
1. Tune the TV to the desired program.
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
Oct 08, 2009 | Toshiba 36HF72 36" TV
Toshiba 50a50
It sounds like you are in Closed Caption Text Mode. You should be able to get into the main menue with the Toshiba remote, get to the close caption Icon and turn off Close Caption. This should take care of it.
Hope this helps,
Skyassoc
Jun 19, 2009 | Toshiba 50A50 50" Rear Projection...
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Toshiba 32AF41 32" TV Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
