Hello Try these links to download the driver for your MP3 player. After download the driver, install it to computer. Your device will be detected after proper diriver installation. driver
Having same issue, battery will not charge. Can't even use it unless its plugged into my computer the whole time. Followed the charging instructions, "turn power switch on and then use the usb cord provided to plug the device into the computer." I do so and it reads that it is charging, however the bar never goes to the green charge symbol. It said to not let it charge past 8 hours so I always unplug it before that. Even tried the recommended 3-5 hours and still I turn it on and it says right away battery low.
connect
the Sansa (via the player's USB cord) to different USB ports on the
computer until the Sansa starts to charge. A weak or non-working USB
port won't charge the Sansa.
Reset the Sansa MP3 player. Slide the player's "Power"
switch all the way up to the "On" position. Hold the switch in that
position for 20 seconds. The Sansa resets. Try to charge the player.
Install the latest firmware onto the Sansa MP3 player.
Download the Sansa Firmware Updated (link in References), and then click
the link in Resources for the specific model of Sansa you own to learn
how to update the player's firmware.
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
You can buy a USB cord at Walmart or any other retail store like it. Except for the iPod all other mp3 players have a universal plug on them to be able to charge it or download music. If you buy one of these USB cords, you can then plug it into your computer to charge it and put music onto it. There is also a Plug in that has a USB slot which you can purchase if you choose not to plug it into your computer, but prefer to charge it on a regular 110 wall outlet.
Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
Try charging it up on a different computer. It says in the instructions
that they cannot guarantee the charging of the battery on personally
assembled or modified computers. I had the same problem with mine on
our independent computer shop bought PC, but it is charging up fine now
that I've plugged it into my hubby's laptop which was bought in a PC
supermarket. I hope this helps.
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
if your mp3 player comes with a usb charge cord and has no bulge in the cord, such as would contain some kind of voltage modification electronics, then it's ok. the reason is: both the motorola charger and the usb port are 5 volts, all usb is 5 volts standard, and the motorola charger is labeled 5 volts right on the unit itself. The the only possible problem would be if the motorola charger was wired differently. However I have been using my razor charger to charge my Emerson 2GB mp3 player w/no problem. Plug in the charger with the mp3 player powered up, you should see the battery icon filling up just as if you were using the usb charger. if you are still to worried to try it , then get a voltage meter and test the polarity (weather positive and negative are the same on the motorola charger as the usb cord when plugged into the computer.
