Symphonic WF20D4 TV Logo
Posted on Mar 17, 2013
How do you get the menu on when using a universal remote
Will a universal remote work? How to access the menu?
A universal remote can work with your TV, but whether it can access the menu depends on the specific model of both the TV and the universal remote. Universal remotes are designed to be compatible with a wide range of devices, including TVs, DVD players, audio systems, and more. However, not all universal remotes have the same features or compatibility with every function of a specific TV.
Here are the general steps to set up a universal remote with your TV and access the menu:
  1. Check Compatibility:
    • Ensure that your universal remote is compatible with your TV model. The packaging or user manual of the universal remote should list compatible brands and models.
  2. Find the TV Code:
    • Locate the code for your specific TV model in the documentation that came with the universal remote. The manual should include a list of codes for various TV brands.
  3. Program the Universal Remote:
    • Follow the instructions in the universal remote's manual to program it for your TV. This usually involves entering a code that corresponds to your TV model.
  4. Testing:
    • After programming, test the basic functions like power, volume, and channel to ensure that the universal remote is working with your TV.
  5. Accessing the Menu:
    • Most universal remotes have a dedicated "Menu" button or a button labeled with a similar term. Press this button to access the menu on your TV.
    • If there isn't a specific "Menu" button, look for a button with an icon that resembles a list, settings, or options. Sometimes, these buttons serve the same purpose.
    • If you're unable to find a dedicated button, refer to the universal remote's manual for guidance on accessing the menu or adjusting settings.
  6. Navigating the Menu:
    • Once you've accessed the menu, use the arrow buttons or navigation buttons on the remote to move through the menu options.
    • Some universal remotes may have an "OK" or "Enter" button that you can press to select a menu option.
tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
1helpful
I have set the t.v. up with a magnavox universal remote control, and I can't find the up and down or left to right to hookup wifi
If you are trying to set up WiFi on your TV using a Magnavox universal remote control, you may need to use the remote's navigation buttons to access the TV's settings menu. These buttons are typically labeled "Up," "Down," "Left," and "Right," and they are used to navigate through the TV's on-screen menus. To use them, follow these steps:
  1. Press the "Menu" or "Settings" button on the remote to access the TV's settings menu.
  2. Use the "Up," "Down," "Left," and "Right" buttons to navigate through the menu options.
  3. Select the "Network" or "WiFi" option and follow the on-screen instructions to set up your WiFi connection.
If you are unable to access the TV's settings menu using the remote's navigation buttons, you may need to refer to the user manual for your TV or universal remote for more detailed instructions. Alternatively, you may need to contact Magnavox or the manufacturer of your TV for assistance.
How can i tune my tv using this remote. I have the remote working but now need to tune the tv with it?
Should be a menu button or on some universal remotes there is a sub menu accessed from the buttons on the side of the lcd screen.
Lost remote and using a universal remote but cant change pictures ratios, how do you change on a universal remote
use the remote to get the on screen menu ( press menu button on the remote)
move until you get aspect ratios
select what you want
ok and exit.
Sharp tv lc 32sh12u menu
Just open the menu by using the universal remote control, and do the rest by using Up/Dn & Left/Right buttons at the the TV front panel.
The pip got stuck using a universal remote..i cannot clear it no matter what button I use
If you can access the Menu options with your present universal remote, get into it, and surf thorugh picture adjustment and PIP adjustment screen, and set the PIP option to OFF. If you can't access the Menu option with your present remote control, there is no other way to do this without its original remote control.
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
Unable to access menu with remote control
you cannot enter into menu on most universal remote only on off switch,channel change and volume up and down thats the most you can get out of a universal remote.you will need the originald remote.
27" Sansui
you might not be able to use a universal remote to access specific functions on the TV.  The universal remote was designed for basic use, and has slightly evolved, but still lacks in some areas.  I suggest finding a Sansui remote, specifically for that TV model.
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
