Maytag MAH2400A Front Load Washer Logo
Pamela Dellal Posted on Mar 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drum rotating unevenly, squeaking
It's possible that some clothing got caught beneath the drum
Mike Pym
Level 2:
New Friend:
  • Expert 168 Answers
  • Posted on Mar 16, 2013
Mike Pym
Expert
Level 2:
New Friend:
Answers
168
Questions
Helped
38497
Points
464
If the drum moves up/down side/side without the outer drum moving, bearings gone, replace. To check for clothing, which I doubt, remove front seal outer section, look around outer part, to bottom you probably find clip, prise apart, front back, not side ways, refit sideways
Loud grinding noises and black streaks on clothes
Your drum rollers may be going bad (grinding noise) which will sometimes cause the drum to drop slightly, creating a gap where the clothes get caught as the drum rotates. (black streaks)
Clothes getting caught between drum abd frame - above door on right side. Also drum is squeaking.
these are the parts, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
Our cloths are snaging between the dryer door and the front wall on the handle side of the door (left side). There so stuck that they rip a hole in them when we free them.
Sounds like you front drum support / bearing is wearing out. When the support wears out, a gap occurs between the drum and drum support, That is where the clothes are getting caught, Does your dryer squeak when running? If so, then replace the front drum support / bearing. Cost about $35 - $40.
1helpful
Articles of cothing get caught between the rotating drum and the frame--I'm sure these are not the correct structural terms. Too often, when I open the door, something will be caught and hanging, and I...
Your drum seal between the drum and the body of the dryer needs replacement, this is what causes the clothes to stick and tear holes in them.
I hope this helps
Please rate me
1helpful
Black marks gets on clothes as if they're getting caught in something.
Our Hotpoint DLL2650 has the same symptom. A bearing has been squeaking for over a year. Now one of the drum rollers makes a grinding sound against the drum. I suspect the drum roller has come apart.
Dec 05, 2009 • GE Dryers
SQUEEKY NOISE WHEN IT IS RUNNING
A great number of dryer drums rotate on a type of felt material. After many years of use this material thins, allowing the drum to make some contact with the metal housing beneath - hence the 'squeak.'
Nov 17, 2009 • Dryers
2helpful
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
1helpful
My dryer squeaks and keeps eating the clothes and leaving burn marks on spots on them because it gets caught in the turn part of the dryer, it is a hotpoint electric dryer, what can cause that?
Squeaking is the rear drum bearing. The rest is the front drum slide supports. After a number of years, these wear and need replacing. Without the model number I can't give you the part numbers that fit your machine.
3answers
G E dryer
Open the service panel and look for a broken belt and does the motor spins. Let me know if you will need for further assistance. Good luck!
Sep 08, 2007 • Dryers
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
