Lenovo ThinkPad T500 Logo
Posted on Mar 16, 2013
Bios password locked - Lenovo ThinkPad T500
Aryan's World of Electronics
Level 1:
New Friend:
  • Contributor 45 Answers
  • Posted on Mar 29, 2013
Contributor
Level 1:
New Friend:
Answers
45
Questions
Helped
13589
Points
75
Please flash the bios.......wid this software.....
click the link and download it...then install it....
yaa...why not.......The 64 bit link is...------ http://download.lenovo.com/UserFiles/Driver/en/Downloads%20and%20Drivers/Z460Z560/BIOS/29CN38WW/NIWEx215_X64.exe.
1helpful
How to remove BIOS password
If you have the current password, use it to access the bios password screen in your BIOS menu and leave the new password blank.
Assuming you don't have the BIOS password, there is generally a white jumper connecting two pins on the system board. With this removed, the BIOS password will not lock out changes to the BIOS. This is especially useful if you've purchased a used system that the previous owner locked out.
tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 • Computers & Internet
LG bios password locked
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
Good Luck!
3helpful
2answers
How to unlock the hdd password
I have a problem with my laptop hard disk.
the hard disk so I locked my laptop not open.
I tried to reinstall it can not.
I ask you a solution how to solve this problem. thank you
Harddrive bios is locked. typed password in 3 times corectlly now bios is locked. what can i do?
Remove the back up battery of ur BiOS, FLUSH the bios and wait for 5 min. Restart ur computer w/o the backup battery.... the password will be gone! Reinstall the battery if the bios password is gone! Taah!
2answers
Its locked and needs a code
Is it locked it in BIOS or in Windows? If it's locked in BIOS, you will need to open up the laptop and locate the jumper and remove the CR2032 battery from the motherboard.
If it's locked in Windows, you would need to re-install Windows again to reset the password.
But if it's locked because of the product key code, then you will need to call up Microsoft automated telephone line. Just have the internet access ready.
3helpful
2answers
Fujitsu Siemens AMILO Pro V2000 PC Notebook what default BIOS password My computer is locked
there is no default bios password
all i know at the some fujitsu laptops if you enter 3 times wrong bios password the computer locks
This is a security issue
2answers
Phoenix bios password
The thing is that somebody set bios password. On phoenix bios based on intel platform? like yours normally if you will enter bios password incorrectly 3 times bios will lock the computer and it will generate 12 digit lock code. You will need to contact Toshiba technical support to get bios unlock password. (Normally this is generated by them within couple of hours.)
I would recommend you to check with toshiba support before locking bios (entering password incorrectly 3 times)
3answers
Help
ohhh..not too cool..reboot and press F2 during logo logon..and then reset it in there..
2helpful
2answers
I set the power on password on my ibm 600e and now cant turn it off. How do I do that
go to www.ibm.com go to support page, download the service manual of your model first, it will show you how to reset your bios password or remove your bios passord, usually remove the bios password, it is your CMOS battery (look like a calculator battery) unplug it, and put it back on again, your bios password should disappear. make sure remove the battery first.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
