Question about Asko W600
I have an asko w600. I need to change the door latch. How do I get to it.
I've taken off the clips and have tried to take the front panel off. I don't know if it is just stuck or something else needs to be unsrewed.
Posted by William Headen on
5 Related Answers
Rotu
Douglas Henry
  • 175 Answers
SOURCE: Asko W6021 front load washer door stuck!
there is a little red loop that you can pull on to release the door manually. it is located behind the little door on the lower left of the machine. Pop that door open and take the phillips head screw out of the lever hen pull on it and the door will open.
Posted on Feb 24, 2007
Anonymous
  • 166 Answers
SOURCE: Asko W600 won't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Mar 21, 2009
Anonymous
  • 24 Answers
SOURCE: Electric door release stopped working
does it not have a manual door release pull next to the filter
Posted on Aug 05, 2009
spre_lucia
SOURCE: Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Posted on Sep 18, 2009
rickead1
Rick Ead
  • 1998 Answers
SOURCE: asko washer door won't close. Worked it manually
you would start at the top back by losening the screws that hold the upper cover on the machine and when you remove these screws you would then slide the panel to the rear of the machine. nest you will see the rubber gaskey along the door has a metal ring simply use a screw driver without ripping the rubber boot to remove the ring. After this then u can remove the screws which hold the front panel which also has the door on it the part you are describing sounds like the door hasp or the catch the holds the door closed. because it is an asko your probably better off going to manufacturer to order your parts because this is a foreign model. please remember to rank how this opinion has helped in your appliance situation and if i can answer anything further please message me back
Thanks again
Rick
Posted on Nov 28, 2010
Testimonial: "Great advice thanks, now to see if I can do it...!!"
Asko w600 won't machine wont spin and wash,
Your Service Manual is here:
Asko W600 Service Manual
Try pages 20 ~ 22
Anthony
Jul 09, 2018 | Asko Washing Machines
I have Asko washing machine W600/Quattro 1000 and it is not closing the door all of a sudden - so not able to do washing.
Try lifting up on the outer bottom corner when shutting the door, if it shuts that way then there is probably a loose screw on the hinges that needs tightening.
Jan 25, 2017 | Asko Washing Machines
Asko w600 front load washer did not spin water out of clothes. I emptied the drain pump and now it fills with water but doesnt wash the clothes. The water drains out but nothing else. Help
Check to see if your model has a "out of balance" micro switch.
If it's tripped from you moving the unit around you may have to reset it manually. It will be mounted somewhere close to the outer perimeter of the tub. Can't say exactly where. Could be high or low.
Jul 11, 2012 | Asko W600
How How do I fix my broken water line that goes in to the freezer door to the water dispenser?
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
I have an asko w600 front load washer, seems to wash ok, but will not go into spin cycle, drain pump operates - slowly, but does not start spin cycle. saw somewhere on net that pump may be faulty
Hello Greg, welcome to FixYa.
To address your post of the washer not spinning and your curiosity of a faulty pump...the pump may simply be obstructed preventing a proper drain, thus a compromised spin, they are directly related. These frontloaders will not spin until they drain sufficiently. (though a faulty drain pump is possible, it woud be the exception, not the rule).
There is typically a drain filter in the pump as you may or may not know, based on your description it may be clogged. You'll need to access it, clean it out via draining it through the pump "emergency drain hose" before you can in the end open the door (though usually once drained to a safe level it will open under normal procedures) however there should be a door lock release on Asko built machines...including the W600 series.
This is the procedure for machines of the past 10yrs. or so...(this is only an example, it may not be exact but essentially the same as yours)
Hopefully this will help. Let me know if anything is unclear or If I can assist you going forward. Thank you for choosing FixYa and good luck going forward.
Regards,
Macmarkus :)
Nov 21, 2011 | Asko W600
I have an Asko W600 front load washer that does not spin water out of clothes. It fills, washes, empties but does not spin- skips this part.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Asko W600
We have an f2 error cleaned pump and how do you open front door with error
Hello, welcome to FixYa.
There is typically a drain filter in the pump as you know, however there should be a door lock release on Asko built machines...including the W600 series.
This is the typical procedure for machines of the past 10yrs. or so...
Hopefully this will help. Let me know if anything is unclear or If I can assist you going forward. Good luck.
Regards,
Macmarkus :)
Jun 21, 2011 | Asko W6641 Front Load Washer
I've an Asko Front loader W600 bought in 2001. It's been excellent, but has been shuddering and moving a lot lately. Today the door won't open and there is no power. There is washing in...
Hi, welcome to FixYa.
I'll start by addressing the later part of your post first, and that is by saying I wouldn't run out and buy a new washer...not yet anyway.
You should be able to get the garments out of the washer by way of manually unlocking the door. The door can be opened manually, see below for instructions.
**Watch for lots of water if it hasn't drained though...see below for manually drain as well**
Usually if the door won't open it's due to the unit not draining sufficiently (this may explain the "shuddering" as well if pump has debris within it) or perhaps a fuse tripping, thus no power. Just to be thorough you should check the pump to insure the filter isn't clogged, in my opinion, or do you know where it is and how to check it ?
In the event the pump, filter or hose is clogged or obstructed, will prevent the door lock from releasing...potentially causing a fuse to trip.
This is by design, but it's easy to confirm or dismiss.
Check as follows...
Let me know if any of this isn't clear and I'll attempt to help you move forward by way of possibly emailing this info to you.
Once you've cleared the pump filter or ruled out it was indeed blocked or not, you can now pull the manual door lock release located in the same area.
i.e.
Once that has been done, I'd now check the fuses in both the washer as well as the dryer...if yours plugs into the dryer as most Asko do. To do so is as follows...
CHANGING THE FUSE
1. Remove the fuse holder insert with a screwdriver (1/4 turn).
2. Replace the fuse. (The fuse must be a 250V, 15amp slow-blow fuse.)
3. Fit the fuse holder insert with the fuse into the fuse holder.
Let me know how you make out. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided for you here today at FixYa.
Regards,
Macmarkus :)
May 31, 2011 | Asko W600
Aug 05, 2009 | Asko W600
Washing Machines Logo
103 people viewed this question
Top Asko Washing Machines Experts
Michael Thomas
Michael Thomas
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
