SOURCE: NEED TO REPLACE HEATER ELEMENT
You should be able to take off the back panel and see it. The heating element is USUALLY an easy fix. Let me know if you need any further help.
SOURCE: When I turn on my dryer on it gives a rattling/vibrating noise.
There maybe a lot of lont build up in the blower wheel housing. Take off bottom panel and take apart the blower wheel house and check for any lint build up....if it check ok, your drum rollers maybe worn....try checkin the blower wheel housing...hope this helps
SOURCE: LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
SOURCE: The dryer tumbles, but doesn't heat
It is a breker in the dryer and you can reset it yourself and het it fixed and drying. Hre is how you can do it...
If you lift off the top by prying it up in the 2 front corners with a flat tip screw driver it will lift up to the back and then take out the 2 top front screws.There are 2 screws in the front off the lint catcher that you get to by opening the front door take them out and then the front off the dry comes off. Then you have to look at the heating tube (where the gas is ignited and the fire burns, which is in the bottom of the dyer under the drum) on the sides of the tube are sensors that are in holes in the tube, There is one that is on the side of the tube on the inside towards the middle of the dryer, it has 2 wires connected to it and in between the 2 wires where they connect to the sensor is a very small button which is a breaker. Push the button in and the gas will start to ignite again and you will get heat in the drum. I am not sure why this does this but it will happen more and more if it starts to happen, so you will start to get used to taking the front off. A service man showed me this after his 3rd trip within days to my house after I asked him how he was fixing it so fast without replacing anything. This was within a year of purchase... I am acually going to replace the switch to see if this will stop it from tripping like it does now which sometime can be as much as in between every load or can go for weeks with no problem....I have the matching pair of LG Front Loading Washer and Dryer which were very expensive and although they do a great job when working it is when they are working that is the problem. Since being new in 3 years both have broken numerous times including this self repairing pain in the *** problem which you are just starting to go thru. I have just gotten done fixing the washer for the 5th time by installing a sensor on the motor to keep the drum spinning this is 2nd one and I can't even tell you how many other repairs I have done. But I can telll you I can take apart to pieces by memory both of them in minutes from doing it so much and for the money spent this should not be this way. You should not have to spend a couple thousand dollars on a washer and dryer and have to become a repair man for the LG company just to get your wash done but yet this is what hapeened to me and it isnt right..LG was great the first few times with service calls but would not replace them and after a while you get sick of waiting for service and just start fixing it yourself, it is just easier and faster...wish I would of bought something else, :-(.....I have had $400 washers ans dryers that lasted 15 years with no problems that did as good a job as these......:-(
