Question about GE Refrigerators
Ge profile pss25sgna - freezer 60 degrees and fridge 58
Refrigerator suddenly acting up - freezer is at 60 degrees all frozen food melted. Now the freezer is completly dry - no ice, no trace of water. Same problem on the fridge. Any help, - should I change the mother board or compressor or ..? Appreicate any help Thanks Pals
Posted by Peter Nathan on
daniel hendrickson
    President:
  • GE Master
  • 1,922 Answers
The compressor is not running,you need to buy a new ptc overload/relay and replace the defective one on the compressor,it unplugs off the side of the compressor,its what starts and runs the compressor
Posted on Mar 16, 2013
5 Related Answers
Anonymous
  • 54 Answers
SOURCE: My GE Profile PSS26MSTSS is not keeping food cold.
You need a new defrost heater
Posted on Jan 04, 2009
Mark Nichols
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: Ge Profile fridge
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Posted on Sep 06, 2009
Testimonial: "Quick, professional response."
aasc
Mike Smith
  • 1606 Answers
SOURCE: GE refrigerator, ice melts in ice bin
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on Nov 16, 2009
dennis dodge
  • 1891 Answers
SOURCE: GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Posted on Feb 04, 2010
What temperature should my GE profile fridge be set at so that my food does not freeze
depends on what type control you have . what is it set on now 6 then turn down to 3 or 4 .
Feb 27, 2015 | GE Profile Spacemaker Stainless Steel...
Water does not work. Possibly frozen line. i keep
I have a GE PSS25SGNA no ice no water freezer side is reading -2 refrigerator side 25 everything is freezing help
Jan 03, 2011 | GE PSS25SGNBS Side by Side Refrigerator
My GE Profile Artica ice maker is making ice, but when I open my freezer, there are icicles from the ice compartment one the food below the ice maker and dripping down the inside of the freezer. The ice...
Hi!!
The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
There are various reasons this type of problem:
The temp. controls are not set properly. Set controls according to manufacturer recomendation.
The small fan in the freezer is not working,
The defros timer is not working or,
The defrost heater coil is busted.
Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
Don't forget to rate this post. Good Luck.
Jun 07, 2010 | GE Profile Arctica Stainless Steel Top...
Ge Profile fridge Model #PSC25MSTASS Wacky temps in Freezer for several weeks, so much so that ice will not stay frozen, so we just shut the ice maker off. Most of the other foods would stay frozen,...
Sep 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer Does Not Stay Frozen
one of the hardest things to diagnous is food defrosting in the freezer. i found out the hard way about 35 years ago, but not until i banged my head against the wall a few times. the problem was the customer didn't have enough food in the freezer as she was a weekender.frozen food needs frozen food to keep the food frozen confused? so was i . every time your refrigerator goes into defrost( usually every 8 hours) a heating coil comes on in the back of the freezer. if the freezer is not full enough this heater can raise the temperature in the freezer to 40 degrees which will soften the food and melt the ice considering the time it takesto refreeze the food. i never forgot that service in fact i can see it in my head right now.. try this cure first let me know
Feb 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Jun 17, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Refrigerators Logo
181 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
