Main evacuation pump runs constantly as soon as the mains is switched on. Control panel lights up but cant stop the pump.
This means the flood circuit is triggered. There is a leak in the dishwasher causing water to collect in the motor chamber. The leak is usually through the door seals or broken hose. Disconnect mains electric and water connections and pull dishwasher out from under kitchen bench. Tilt it from side to side to get the water out from under the base. Wait a little for water to dry up. Reconnect mains power and turn on to see if pump stops running. As mentioned source of leak needs to be fixed.
SOURCE: fisher and paykel DD-603 dish drawer
Hi there, If you have had an F1 you need to dry out the product in order to reset the flood switch. This is a simple process as follows: 1. Ensure product is disconnect from wall so that it has no power. 2. Open the bottom drawer and put your hand in through the gap where the bottom of the bottom drawer comes out and feel the base of the cabinet that houses the drawers for water. 3. If there is water present dry it out as much as you can with paper towels or old rags. This machine is designed to drain all water to the front of the base of the cabinet away from the flood switch that sits at the back left corner of the cabinet base that the drawers are fitted into. 4. When you have base of the cabinet dry you need to ensure that the switch has not moisture on it in order for it to reset and allow you to start using the product. This can be done 2 ways: 1. leave bottom drawer open for 24-48 hours to allow natural air circulation to dry out the connection. or 2. position a hair dryer to blow air into the back left corner of the base of the cabinet and dry it out quicker. This still make take up to 6 hours as the flood switch had a protective cover over it to try to prevent F1's for small spills. 5. When the product had been dried out, important that you make sure it has, when you switch on the machine the F1 should be gone and ready to use. Please run each drawer seperately on a rinse cycle to confirm to yourself that it flooding was possibly caused by something blocking the sprayarm, or something stacked too high or something got stuck in the pump temporarily stopping it from draining effectively or the product suddsing too much from spilt rinse aide in one of the drawers. If each drawer runs successfully you should be in the all clear to start using it again. Please note though: if something blocks the spray arm that is directly linked to the pump your drawer will flood as a result. If you have something stuck in the pump peventing it from draining effectively ie a toothpick or piece of broken crockery this will cause your product to flood, but you will hear an louder than normal sound when the pump is running. And finally if you spill rinse aide in your drawer when filling it clean all spilt rinse aide to prevent unit from over sudsing when running. Regards KAR-Ltd
SOURCE: haywire dishwasher contol panel
I had the same problem. Played Fur Elise and the Star Spangled Banner when you press and hold the middle button. Before that it was not draining and the lights were blinking blue and red.
I found the breaker to the power for the dishdrawer, turned it off, then back on. That seems to have worked. We are not thrilled with the number of times we have had to call for service or run an extra rinse cycle because the top drawer did not drain all the way. We got a full rebate for the cost of the unit when we bought a DCS range and hood so it was free. Not sure I would buy on though.
Good luck.
SOURCE: My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
SOURCE: dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
SOURCE: Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
