Dell PowerEdge T300 Server   Logo
Anonymous Posted on Mar 15, 2013
Dell T300 memory config error - Dell PowerEdge T300 Server
Anonymous
Level 3:
  • Dell Master 2,878 Answers
  • Posted on Mar 28, 2013
Anonymous
Dell Master
Level 3:
Answers
2878
Questions
0
Helped
488108
Points
8243
Verify size and type off memory. Also the slots used are a variable. There should be DIMM configuration table on the removable panel or better yet look for the manual.
Dell poweredge t300 server e1410 cpu 1 error
The e1410 is an error that is reporting an interruption to the CPU processes. It isn't identifying an issue with the processor specifically, it is just saying its processes were interrupted. Normally when you see the E1410 you will see another error listed with it in the hardware log. Do you see any other errors in the log? Also, what is the BIOS and Drac versions at currently? I ask because the server being very out of date can cause issues like this as well.
Let me know what you see.
Open poweredge t300 to replace ram
He shows you how to open the server then you should see the memory.
Error E2011 Memory Config
It sounds like the servers have different memory modes selected :)
Error code 2900-0325
Use GOOGLE and SEARCH for:
First Search for:
Dell PowerEdge T300 Server list of Error codes
(12,600 hits)
then search for:
Dell PowerEdge T300 Server Error code "2900-0325"
(You will find 40 'hits')
Anthony
Configure Dell Poweredge T300 to boot from optical drive
BIOS must see the optical drive. Re-seat / attach drive if it does not. The other option is to use another drive.
Error message on server says to call support.
Disassemble Components an Clean the System with Air blower,
& Assemble Components Check it
Nic teaming on poweredge t300
NIC teaming is useless unless you have a switch that support teaming.
However, Dell servers have free lifetime phone support ((800) 945-3355).
They should be able to help.
6helpful
Error message E1810 HDD 0 Fault
go here
http://support.dell.com/support/edocs/systems/pet300/en/hom/html/about.htm
1helpful
Dell says I could not load WinXP Pro on Dell T300. Why not?
You won't encounter any problems, but you may need a usb to ethernet adapter to get on the internet to get drivers. Also, many places no longer sell non-OEM copies of windows XP, and, will Dell sell a computer with no OS?
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
