I am looking for the routing diagram for the scanner cable. The cable is still attached to the scanner unit.
SOURCE: Toshiba estudio 28 with GL-1010
you cont need and cables to connect it as all the connections are internal.
does the gl1010 light up and does the cd rom open and close when you turn the copier on?
SOURCE: Toshiba 3530c estudio waste toner error message.
Your waste toner box is located inside the front cover on the far left side of the copier. There is a plastic cover that is just clipped in (no screws) and just pops off, the waste toner box just slides out from there.
SOURCE: remove hard drive from estudio 450
Pull off the back cover, then the metal cover that has the two wire fan plug going in to it. The hard drive is under there.
TOSHIBA PARTS AND SUPPLIES
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
