Question about Samson C01U Consumer Microphone
Samson Co1U don't work with windows 7
Hello, When I plug this mic (I test it with 4 PC with windows 7 ) no drivers are found to install it correctly. I can see USB Audio Device in the Device Manager of Windows 7 with an question mark. I tried to uninstal and replug but the problem still continue. In the general properties it's say : This device cannt start code 10. Have you got this problem too ? Have you a solution ? Thank you very much. A poor french boy.
Posted by rom_g2 on
2 Related Answers
multilinkent
HTS Sri Aman
  • 739 Answers
SOURCE: Salut I bought a new Laptop
hi,
Your problem is there are 3 reasons
The first connection of your USB mic problems
The second USB port of your computer problems
three windows system problem or virus
The first thing you do a test using a different computer and see the results. If the problem still the same this means that your microphone usb connector problem
Second, if your microphone is successful on the computer this means you need to perform tests on the USB port or your asus laptop operating system, most likely the problem is the USB port or an operating system.
regards
Posted on Feb 20, 2011
krb55
Keith Brown
  • 604 Answers
SOURCE: Samson CO1U won't work -
hmm that is strange, are you seleting the mic as an input in the source for audio? the software works on win 7. have you tried other mics in the input on your sound card?
Posted on Mar 20, 2011
Samson CO1U won't work - it's installed fine, the sonar LE cakewalk has installed aswell.. but for some reason it won't let me click on the Microphone to use as input. i am using windows 7 - will that have...
Mar 19, 2011 | Samson C01U Consumer Microphone
I dont know why i can not record my mic into my nuendo4
plz first setup your driver. ten setup nuendo 4. device setup-vstaudio system-click switch
Apr 04, 2010 | Intel Steinberg Nuendo AudioLink PCI 96...
I cant hook up mic and guitar same time
get a 1/8" stereo to mono splitter from radio shack or the like. it should have 1 1/8"male end, and two female ends, you could possibly get a 1/8" male with 2 1/4" female connectors, or use an all 1/4 inch adapter, with a 14/ to 1/8 adapter on the male end.
this should divide the guitar and vocals into left and right channels.
Feb 27, 2009 | Edirol UA-4FX External Sound System
SAMSON CO1U recordings sound like they're underwater on my MAC
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Feb 10, 2009 | Samson C01U - USB Studio Condenser...
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Cannot hear sound from mic on Samson CO1U.
i can't install logitech desk mike model ak 5370 in vista
Jan 03, 2009 | Samson C01U Consumer Microphone
Sound quality not good at all
open up the sound icon on control panel...select recording......select samson mic....make sure set to default.....go into properties ...and boost main volume slider....most mics after install are set quite low and you have to go in and adjust the vol input level
Jan 03, 2009 | Samson C01U - USB Studio Condenser...
SAMSON CO1U USB MIC FAILURE
Your first issue is vista... it just sucks. I would have to be there to figure this one out but im going to state the obvious, does it have an installation cd you didnt use? does it have online drivers you can find? Try looking around in your control panel and messing around with some of the options, good luck.
May 01, 2008 | Computers & Internet
Problem with Samson CO1U
Here are some instructions relayed from someone who was able to fix a similar problme with help from Samson tech support:
The C01U is a WAV device. Therefore, adjusting the slider for your default MIC input level on the volume control applet does not adjust the gain on the C01U. You access the actual volume control for the C01U as follows:
Start, Settings, Control Panel, Sounds and Audio Devices
Click on Audio tab.
Under "Sound Recording", insure that Default Device is selected as Samson C01U.
Once Samson C01U is selected as Default Recording Device, click on the Volume button just below the name. A new window will pop up, with a vertical slider. This window will be labelled "WAVE IN", however it actually does control the MIC volume for the C01U.
The key here seems to be that the USB device that represents the Microphone input (as far as Windows is concerned) is not a traditional microphone, but (as mentioned above) a WAV-IN device.
Jan 03, 2008 | Samson C01U Consumer Microphone
Samson C01U Consumer Microphone Logo
103 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
