Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Check main controller for dust build up. if so remove all sub boards and carefully remove any dust from all boards and its connecting areas, clean all contacts. try not to create much static round the boards. re-seat all boards (remember where they go), test.
E602 is a faulty hard drive located in the same area, this may need replacing and loading firmware onto it. - requires technician to load new firmware
i looked to see if there was a user fix for this problem but there isn't. It sounds like the driver pcb board could be blown and or the fixing assembly needs replace.
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041. To clear the error: * 2 8 * COPIER FUNCTION CLEAR ERR OK Turn off and on ( main switch )
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below. - E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.) - E732-8888 can be displayed when a different scanner is connected to this machine.
Probably the copier is iR C5185i - E004 = Fixing unit protection circuit trouble
- 0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the FU261). In the service mode, clear the error by selecting COPIER > FUNCTION > CLEAR > ERR. You need a canon technician to resolve this problem.
