Question about Stihl Ts 410 420 Cut Off Saw Decompression Grommet
What is gap on pickup mag to coil - Stihl Ts 410 420 Cut Off Saw Decompression Grommet
New coil and still no spark on my GC 160 Honda tiller
Did you check the gap between the magnet on the flywheel an mag? Unplug the stop wire an see how that works. Sometimes the switch is bad. Are the magnets on the flywheel, did you set the gap on the flywheel to mag correctly? Did you do the simple thing an change the plug they go bad more than anything else.
Mar 25, 2014 | Garden
Air gap setting ignition coil
if you didnt adjust it you dont need to know
it is the gap between the rotor for the pickup coil and the coil pickup face
the ignition coil makes energy from the rotator to feed the spark plug
you need to tell us what is up
your question is incomplete and lacks details
Dec 05, 2013 | Stihl Bg 55
No spark on a 126T020675B2 Briggs 6.75 hp mower engine
gap needs to be 10 thousands of a inch done with a brass feeler gauge ..mag/flywheel has a spot with a magnetic field if you look you can see it it should make a 1/2 wrench stick to it if not replace mag/flywheel ..check key way also
Jun 05, 2013 | Mtd 22" Yard Machine Push Mower
Need coil mag air gap for homelite model ut20006 line tremer
You can set the air gap for the coil with a business card used as a thickness guage.
Sep 06, 2011 | Garden
Briggs and stratton motor w/ points 5 or 8 hp. withintermittent spark. i checkep points and cleaned. gap looked good. checked coil wire, no cracks or shorts. cleaned mag mag and coil pickup. checked ground...
If selled some capacitor or new ignition parts order it always with statement of the serial motornumber and the year of build , because of modifications on marketing technical dicisions can be made for your engine, that can prevent a next disappointment. may be for the problem a new sparkplug the supression capacitor can also be bad a bad sparkplug connection cable .are some small sugestions.
Jan 26, 2018 | Briggs & Stratton Ignition Kit 2-8 HP...
Replacing coil pack need to know space from mag
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Kohler 12res hunting and surging when running
hunting is usually caused by fuel starvation not an electronic fault
Apr 07, 2010 | Kohler 12 kW Emergency Power System -...
Have 16hp vtwin brigs no fire checked flywheel magnet & replaced
If it still has no fire with the ground wire off, did you set or adjust the gap for the coil??? Try cleaning the posts that the coil mounts on the engine and reset the spark gap
Apr 26, 2009 | Garden
Phono input
If you mean Moving Magnet vs Moving Coil, they are different.
MM is the higher output of the two types so most Phono Preamps can deal with them.
Not knowing the specific receiver model, a direct answer to your second query is not possible. I would guess - YES.
"Since the coils are much smaller than those in the MM cartridge, the MC cartridge generates a much smaller signal."
see this great article where that originates...
http://forum.ecoustics.com/bbs/messages/1/165349.html
Dec 17, 2007 | JVC RX-318 Receiver
Stihl Ts 410 420  Cut Off Saw Decompression Grommet Logo
55 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
