2002 Yamaha TT-R 250 Logo
Anonymous Posted on Feb 25, 2009
My battery isnt getting charged on my motorbike from engine
Can any one help? i just bought new bike (yamaha ttr250 1999) and the battery is not getting charged up. i have to take the battery out and charge it with a charger because it doesnt charge its self.. any ideas? could it be the r/r? and whats a C.D.I unit? also does any one know were the best cheap place to get the parts i need is?
thanks
  • Anonymous Apr 03, 2009
    hiya i bought a honda cbr 125 and my battery doesnt charge either i have replaced the voltage regulator but it still doesnt charge
  • flymoboy Apr 08, 2009
    got new battery after xmas only lasts about 4 days and is flat does not seem to charge off the bike running and my headlight is very dim is all the power going to my lights ??
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
  • Posted on Feb 25, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3089245
Points
19604
Hi and welcome to FixYa,
Almost always, your described problem indicates a charging issue. This points to the bike's battery not charging. Suspects would be:
  • voltage regulator (most likely);
  • connectors to voltage regulator (likely). Check/clean corrosion/burnt marks;
  • stator and/or the wires coming from it (least likely).
A CDI is a capacitive discharge ignition. This is an electronic module that fires the ignition coil.
Parts would depend on where you are. Often, other riders would provide information for parts source.
Good luck and thank you for using FixYa.
  • mattyatkins Jun 15, 2011
    Checked all of this and still have a problem
1helpful
1995 Yamaha SRX 400 Monoshock - How do you check the engine oil level. I.E. with the bike level or leaning over on its side stand?
Mike, engine oil level on motorcycles are normally checked with bike on level ground on center stand (not leaning or tilting in any direction), or have an assistant hold bike straight while level is checked.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Check The Oil On Motorcycle
How to Check Motorbike Engine Oil Level 6 steps
CHECKING YOUR OIL LEVEL
My new motorbike won't start, when I turn the key to on there is no power/ ligths on the digital board
IF IT IS NEW YOU NEED TO TAKE IT BACK TO WHERE YOU GOT IT BECAUSE IT IS UNDER WARRENTY,SHOULD BE AND IT WONT COST YOU ANYTHING,OR MAKE SURE YOUR BATTERY IS 12 VOLTS CHARGED BEFORE TESTING ANYTHING ELECTRICAL SO YOU ARE GETTING A TRUE READING.OBVIOUSLY CHECK FUSES.IT IS QUITE POSSIBLE YOU MAY OF GOTTEN A BATTERY WITH A BAD CELL,IT HAPPENS BIKES ARE SHIPPED IN THE FALL AND IF YOU BOUGHT YOURS IN THE SPRING ,MY GUESS IT WAS LEFT CRATED OUTSIDE FOR THE WINTER
My virago xv535 is having consistent charging problems. I have changed the stator, put a new battery in but the bike will not run when the lights are on. Do I need to change the rectifier? or is there...
you will need a volt meter across the battery,
it should read around 12v with the engine stopped and rise to around 13-14v with the engine running.
If the reading doesnt rise when it starts, then it isnt charging and the regulator\rectifier is the next step.
If you are getting a voltage rise and turning the lights on stops the bike, then there may be a problem in the switches, on \off high \low
Bike will not start or stay running on a full charge battery/bought brand new battery, still same promblem,jump bike off,will crank ,ride bike for 30 min. park bike, leave bike running,lights start's to...
sounds like the problem is your battery is not charging when you are riding. The most common cause is a faulty regulator / rectifier. Contact a motorcycle wreckers for these parts, or your yamaha dealer.
Easy way to test is, when your bike is running, and the lights start to dim, before the bike shuts down, using a volt meter, test the voltage at the battery terminals, should be about 14V. If faulty rectifier,no charge going in to your battery, then the reading will be low, about only a few volts. If you dont have a volt meter, then any mechanic shop can do this test for you. best to have this done before buying any parts.
1helpful
Engine wont turn over at start
Hi, Do you have an alarm & Immobiliser fitted on your bike as these drain the battery on your bike very quickly? If so i would recommend removing your battery and fully charging it with a decent amp-age charger. If you have your garage attached to your house then i would definitely recommend purchasing a trickle charger and when not using your bike keep this plugged into the mains and you should not have this problem again. all motorbike shops sell these chargers If after this the battery goes flat again i would suggest purchasing a new battery. This is a common fault as most motorbikes sit in the garage through the winter months and if not kept on charge will deteriorate. Hope this helps.
3helpful
3answers
No clutch
Yes this is evident in replacing engine oil to motorcycle engine.
Engine oil designed for automobiles isnt good for motorbikes as they offer additives for added "slipping". THis will cause your clutch to slip. Automobile Engine's oil system is separate from the clutch while motorcycle's clutch and engine fall under one oil system.
Use engine oil designed for motorcycles.
Solution: Buy and Engine flush, pour it to your crankshaft, run the engine for 5 minutes (idle) then drain. Replace with new motorcycle oil.
-levibit-
Yamaha FJ 1100
Make sure the new battery has fresh acid in the cells. I did the same thing with a battery I bought and forgot to add the acid and charge the battery up so my bike didn't start. Got distracted with the wife's todo list....
3helpful
3answers
Power is draining form battery and isnt recharging.
could be either a short to ground, or a duff battery. i have a 650 v star and if i dont start my bike at least once a week then i will have to get the booster on it to get it going. my battery is less than a year old but i guessed i bought the cheapest one. it is fine when i ride it recharges but it will deplete over 2 weeks. if it is not charging when you ride then have your charging system checked.
1helpful
Electrical
sounds like you have got dead cells in your battery , they wont hold a charge , the loud click was probably the cells in the battery arking and killing the cells off ,id fit a new battery and all should be well.
hope this helps
kind regards
bert31000
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
