Question about DISH Network Televison & Video
I have problems with Dish Newtorw call history. It will not keep the callls
Posted by Michael Uchytil on
Dish
  • Official Brand Answer
  • 184 Answers
Hi Michael! My name is Kimberly and form part of the DISH Social Media Team. I apologize for the inconvenience you have experienced with our service. Did you try resetting the receiver by unplugging it from the electrical outlet? Did you make sure the phone line connected behind your receiver is properly connected? Feel free to contact me at [email protected]
[email protected]
Social Media Representative
DISH L.L.C
Posted on Jun 27, 2013
Recover deleted history
Hi there Janice, If you have a Hopper system and have deleted all of your recordings, you may recuperate them by pressing 'Menu' on your remote, selecting 'DVR' then 'My recordings' and 'Deleted Recordings' Once you are in the 'Deleted Recordings Screen' you have the option to select 'Restore' (this option will allow you to restore all Deleted Recordings) Unfortunately no other receiver has the capacity to restore deleted recordings.
Kimberly Escobar
DISH L.L.C
Feb 02, 2014 | DISH Network Televison & Video
Hi there Kaci, my name is Kimberly and I form part of the Social Media department with DISH. I am sorry to hear you accidentally deleted your recordings. It is my pleasure to help you. Recovering your recording would depend on the type of receiver you have. If you currently have a Hopper system, under the 'My Recordings' tab select 'Deleted Recordings' once you are in the Deleted Recordings folder simply select 'Restore'. For any other model of receiver unfortunately this option is not available, meaning your recordings have been permanently deleted. If you have additional questions or need assistance with your DISH service, feel free to reach me at: [email protected]
Kimberly. Escobar
DISH L.L.C
Jan 21, 2014 | DISH Network Televison & Video
Help with caller ID history on Dish Network
You DO have to have caller ID service with your phone company for this to work. If you don't, it won't. If you do have it, you need to go into the menu and activate the receiver to use the caller ID. If your problem is something else, you need to elaborate.
Mar 14, 2013 | DISH Network Televison & Video
2001 Oldsmobile Alero Service Engine light, ABS, and Traction light keep coming on. No code, only history. Can not get the history to clear??
Only the computer can clear history codes . If the problem was fixed in about 100 ignition cycles the computer will clear this codes . Code reader . will it check Codes in the EBCM - electronic brake control module ? ABS DTC'S
Aug 18, 2017 | 2001 Oldsmobile Alero
The chuck keeps slipping off. How can I get a new one.
I wwould try a good cleaning irst. If not then try to calll them direct at 1800--879-8000
Oct 25, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
DVR LOST ALL RECORDINGS (EVEN PROTECTED RECORDINGS), ALL HISTORY OF SEARCHES. TALKED WITH DISH & THEY HAVE NEVER HEARD OF SUCH A THING. RECORDED SEVERAL MORE PROGRAMS & IT DELETED THOSE AS...
Hello, Daniel Busa with Dish Network. If this is still persisting you may need a replacement give us a call or you can contact us on twitter and we will get it resolved.
Jun 28, 2010 | DISH Network ViP722 DTV Receiver /...
How do I find History on DVR & retrieve my protected recordings?
In order to find your protected recording in the history on your DVR, you would simply press the button specifically labeled, "DVR" on your DISH Network remote, the DISH On Demand screen will then come on your tv, proceed by selecting "My recordings," on the "My Recordings" screen you will then select the "Sort" option. Once you have selected the sort option it will allow you to specify how you want the recordings sorted- the option you would want to select is, "Protected." I hope this helps you out, let me know if you need any other help! -Kirstie DISH Network
Nov 26, 2009 | DISH Network ViP622 DVR DTV Receiver /...
301 dish keeps losing signel
If keep losing signal, but comes back, then your dish likely has become a bit loose on its mount. That, or the LNB's screw has fallen out.
You could also have trees growing into the beam (those this usually only causes problems in spring when leaves sprout out). Your coax could have moisture getting into it somewhere, or is damaged by a tight bend.
Nov 02, 2009 | DISH Network 301 DTV Receiver
Dish net 311 no power
Dish Network (Echo Star Communications) is a problem company. The best solution to your problem is to switch to cable or Direct-TV.
Dish Network should be avoided at all costs.
May 06, 2009 | DISH Network 311 DTV Receiver
Our kenmore 697267 keeps tripping it's circuit every 5 minutes or so... what's the problem with it? Is it dangerous to just keep resetting it?
definatly a prob if tripping breaker every5 miin, resetting breaker is not good for either the breaker nor hte dryer, that would be hard to determine why without actually looking at though, i would probably calll someone to have a look at that one
May 02, 2008 | Kenmore 73952 Gas Dryer
Televison & Video Logo
82 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
