Question about DISH Network Televison & Video
Help with caller ID history on Dish Network - DISH Network Televison & Video
Posted by Michael Uchytil on
rbmitch
    Problem Solver:
  • 17 Answers
You DO have to have caller ID service with your phone company for this to work. If you don't, it won't. If you do have it, you need to go into the menu and activate the receiver to use the caller ID. If your problem is something else, you need to elaborate.
Posted on Apr 25, 2014
1 Related Answer
Albert Nika
  • 44 Answers
SOURCE: Caller ID function does not work.
Turn off your computer off and temporarily remove the DSL filter to see if the Caller ID then works. If that makes no difference you will need to contact the dish company.
Posted on Feb 15, 2008
Check caller id
Caller ID on the telephone is only supported if the KSU is progammed to pass through this information. If you want to view it on the phone level there is a button that can be programmed on your phone to display like caller ID history.
Dec 11, 2013 | Toshiba DKT2020SD Phone
NO CALLER id.
Caller ID has to be programmed in the brains of the system not at the telephone level. Go to http://www.telecom.toshiba.com/ to find a certified dealer to turn this on. Then have a button put on your telephone so that you can view caller ID history of calls that have come into your desk if you desire
Aug 23, 2013 | Toshiba DKT-2010 Corded Phone
What are the factory default settings? What will I have to redo after the factory default settings are set?
Any customized setting you changed on the receiver will go back to factory default. Here is a list of the settings that would change:
  • Favorites Lists are cleared and the titles set back to List 1 - List 4
  • Search History is cleared
  • Alternate Audio is set to English
  • Closed Captions returns to default settings
  • Mode Reminder is enabled
  • Receiver is set to Dual User Mode
  • Caller ID history is cleared
  • Phone Setup is set to Touch Tone and No Prefix
  • Audio Output: Decoder set to Dolby Digital/PCM
  • Updates are set to 3:00 AM
  • Guide text is set to Small if the receiver is connected via HDMI and Medium otherwise
  • Guide format is set to Standard - Partial Guide with Video
  • Inactivity Standby is enabled
Locks, timers, DVR and Remote Address settings are not altered
Aug 19, 2011 | DISH Network ViP722 DTV Receiver /...
How do I find History on DVR & retrieve my protected recordings?
In order to find your protected recording in the history on your DVR, you would simply press the button specifically labeled, "DVR" on your DISH Network remote, the DISH On Demand screen will then come on your tv, proceed by selecting "My recordings," on the "My Recordings" screen you will then select the "Sort" option. Once you have selected the sort option it will allow you to specify how you want the recordings sorted- the option you would want to select is, "Protected." I hope this helps you out, let me know if you need any other help! -Kirstie DISH Network
Nov 26, 2009 | DISH Network ViP622 DVR DTV Receiver /...
I have a Nokia e71, and everytime I call someone the caller ID on the person's phone says "private caller". How can I change this?
Telephone settings
Select Menu > Tools > Settings > Phone.
Select from the following:
• Call — Define general call settings.
Call settings
To display your phone number to the person you are
calling, select Call > Send my caller ID > Yes. To let
the network determine whether your caller ID is sent,
select Set by network.
Nov 13, 2009 | Nokia E71 Smartphone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
On screen caller id failure
common problem on 625 receiver. Have you hit menu 6-1-2 to enable caller id? If so call Dish and have them send you a new receiver out and give it a try. I'm sure it won't work every time, but it has to be better than what you have.
Apr 25, 2009 | DISH Network DVR-625 DTV Receiver /...
Feb 15, 2008 | DISH Network DVR-625 DTV Receiver /...
Dish network
Codes for Apex are 595, 618, 743, 744, 005, 006, 019, 020, 120, 745, and 757.
Codes for Sony tv are 500, 514, 578, 640, 670, 690, and 758.
If these dont work here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
To set up caller id you have to enable it on the receiver. Press menu 6-1-2, highlight enable and press select. Highlight done and press select. Press 0 three times. Try calling yourself with a cell phone to see if it works, if not, repost on this thread.
Dec 11, 2007 | DISH Network IR Remote Control
Televison & Video Logo
83 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
