Question about HEWLETT-PACKARD Office Equipment & Supplies
Install Deskjet 2510 all in one printer The printer does not print. It is also not listed in PCs printers on control panel.
ABOUT WHAT? tHE PRINTER IS CONNECT AND THERE IS A LIGHT ON. The CD rom went into the disc drive and I clicked on Run and typed in name of program.
5 Related Answers
Anonymous
  • 432 Answers
SOURCE: DRIVER DESKJET 720C
You can download them here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=58707&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Jun 28, 2007
Anonymous
  • 60 Answers
SOURCE: Panel or in All Programs
Lexmark tell us that your printer works with Vista:
Operating Systems Supported Microsoft Windows 2000
Microsoft Windows XP
Microsoft Windows XP Professional x64
Microsoft Windows Vista
Microsoft Windows Vista x64
Try reinstall the driver, here is a link where you can download it:
http://www.downloaddelivery.com/srfilecache/cjr4200EN.exe
If all cables are plugged in and the printer is powered up, you should see it in Printers after installing the driver.
Let me know, rate the solution! Thx.
Posted on Feb 01, 2008
Anonymous
  • 3 Answers
SOURCE: need to download and install drivers for hp deskjet 4280
Click Below Link --> Select Your OS --> Download Drivers --> Simple !!!
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3390948&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=3390945
Posted on Feb 09, 2009
Anonymous
SOURCE: LOST CD ROM
I have disc but adviseu to through away 1610 because if u look at problem they all go bad and won't accept old cartridge until u buy a new one then last for only a short time
Posted on Mar 18, 2009
Anonymous
SOURCE: samsung ml-2510 printer red light on, doesn't print
yes
Posted on Feb 17, 2010
I have installed my HP Deskjet 920c Printer using paralell port but the printer just will not print. I have even tried restarting the computer but nothing happens except a message which says that the...
Check the Device Manager to see if the printer is listed as well as its' driver. Also, check in the Control Panel under printers to see if your printer has an icon. If not, you'll need to install the setup disk for the printer.
Oct 31, 2010 | HP DeskJet 920c InkJet Printer
Attemts to print e-tax summary the printer is defaulting to cd
Click on startà control panelàprinter and faxes.
Click on top left Add a printer option. This launches the Add Printer Wizard. Click next.
Select Local printer attached to this computer and uncheck automatic detect and install my plug an play printer option then click Next.
Now, Use the drop down arrow to select USB001 then click next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Verify the printer name and set the printer as default then click next.
Do not select print a test page option.
Click on Finish
Click on start then run type notepad.
Write any stuff and then try to print.
ADD A PRINTER IN VISTA
Click Start and click Control Panel.
Click Hardware and Sound then Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click on Next.
Select replace current drivers
Click on Finish.
Click on start then search type notepad.
Jul 12, 2010 | HP Photosmart Premium C309A All-In-One...
Its identifying my printer as being offline, how do I correct it
Click on Finish
Click on Finish.
Jul 10, 2010 | HP Officejet 4315v All-In-One InkJet...
How can I make my printer compatable with windows vista.
Windows Vista has the basic drivers for HP deskjet printers. Please follow the steps below:
1. Just turn off your computer, and then connect the parallel cable to the computer and printer.
2. Turn on the computer. You will be prompted to a Found New Hardware window.
3. Select Locate and Install Driver. Make sure to click Allow if the User Account Control screen pops up.
4. Windows will search for the drivers, if it was able locate the drivers then the installation is complete. If not then click Cancel.
5. Go to Control Panel -> Hardware and Sound -> Printers. Select Add Printer.
6. Click Add a local printer. Then click Next.
7. Select Use an existing port. It should be LPT1 (Printer Port). Then click Next.
8. On the Install the printer driver screen, select HP in the list of manufacturers. Then select the model of your printer. If it is not listed, click HP Deskjet 500c. Click Next.
9. Type the name of the printer, then click Next. The printer driver installs. You may click Print a test page to test if it is working.
10. Click Finish.
I hope this helps! Good luck!
Jan 22, 2010 | HP DeskJet 5550 InkJet Printer
Priter does't respond when i used it to print a document
Printer isn’t responding? Please check the following:
i. Is it powered on? If so good.
ii. Is the printer cable connected from printer to your computer? If so good.
iii. Check to see if printer is properly installed. Go to start/control panel/printers and faxes. When the box pops up with the list of installed printers check to see if your printer is listed. If not listed it means your printer is not installed. This also invariably implies that your printer cable (from printer to computer) is bad. Change it and your printer should install and you should be able to print then.
Dec 04, 2009 | HP DeskJet 3550 InkJet Printer
Not printing the whole of the page even all in black ink some parts are randomly missing
Install Temporary Drivers:
Step one: Install a temporary print driver
1. On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2. Click Add a Printer.
3. In the Add Printer dialog box, Select USB001 port, and then click Next.
4. Under Manufacturer, scroll to and click HP.
5. Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6. Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7. In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8. Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9. Click Finish to complete the installation.
Step two: Designate the temporary print driver for two-sided print jobs
Follow these steps to use the temporary print driver each time you print a two-sided document.
1. In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2. In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Aug 18, 2009 | HP PSC 1350 All-In-One Thermal Printer
My ML-2510 samsung printer stopped printing?
Delete printer Icon in the "printers and faxes" dialog box, then use the software installation Cd to re-install it. Also, depending what software that printer uses, there may be a "Samsung" software to delete in "add/Remove programs" in the "control panel" as well. I would delete everything and start from scratch.
Select the proper port when setting up. I assume you are using a "USB" port?
Mar 15, 2009 | Samsung ML-2510 Laser Printer
Printer prints very slowly from computer e-mail
Trouble Shooting steps:
1)Open Internet Explorer
2)Tools >> Internet Options >> Advanced >> Restore Defaults
Now Try to Print Issue would resolve if this issue still persists follow this below steps,.to install Universal Printer Driver
1)Install alternate Driver Deskjet 990c
2)Click on Control Panel
3)Click on Printer and faxes >> Add printer >> Select Deskjet 990c >> Install the printer >> Make it as Default Printer Now
try to print your issue should resolve.
Feb 06, 2009 | HP Office Equipment & Supplies
HP deskjet 648c will not print
Is your printer online? Go to control panel, check your printer list. Does the icon for this printer appear to be somewhat see through or opaque? If so, right click and ensure it's listed as "online".
Apr 14, 2008 | HP DeskJet 648c InkJet Printer
26 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
Lawrence Oravetz
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
