Jvc 37 in flat screen turns on after power is turned off for ten seconds, won't turn off either by remote or buttons on tv , screen also has a blue standby light that flashes
CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
Rating: 1.9 - ‎37 votes
The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
The following steps should be able to correct the problem: 1) Unplug the TV or remove AC power from the TV 2) Count to ten and then plug in the TV 3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel 4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons. 5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons. 6) The TV’s lower left Blue Power LED will come ON. 7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time. 8) Press the [Mute] button on the TV remote twice 9) Unplug the TV or remove AC power 10) Count to ten and plug the TV in 11) The TV power should automatically come ON and the blue power LED with be ON 12) Wait 40 seconds and the TV picture should appear 13) You can now continue using your TV. 14) If the picture does not appear, power on the TV manually: · If the LED begins flashing, unplug and power ON a second time. · If the LED begins flashing again, power ON the TV without unplugging If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you. If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control. 2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote 3) Scroll down to "system info" and select [OK] button on the remote
CHECK UR POWERSETTING AND SLEEP TIMER SETTING......AND RE ADJUST IT IF YOU STILL HAVE PROBLEMS GO IN TOUCH WITH JVC SERVICE AND ASK THEM FOR ADVISE....OR THE STORE U BOUGHT THE SET FROM
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
