Sewing Machines Logo
Question about PfaFF Quilt & Craft Pro 7530
Need a rolled hem foot for Pfaff hobbylock 784-786
5 Related Answers
Anonymous
SOURCE: pfaff hobbylock serger 784 786
I cannot make a roll hem on my Pfaff 784
Posted on Sep 26, 2008
Anonymous
  • 65 Answers
SOURCE: rolled hem settings
Here is a link to purchase your instruction manual:
Pfaff Sewing Machine Instruction Manuals
Posted on Jan 06, 2009
Anonymous
  • 3 Answers
SOURCE: Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Posted on Jan 13, 2009
Ed Paje
  • 632 Answers
SOURCE: lost instruction manual
ebay
Posted on Jul 17, 2009
Anonymous
  • 3 Answers
SOURCE: I am looking for pfaff hobbylock 786 serger manual
ISBN 0-8019-8192-1(hc)? or ISBN 0-8019-8191-3(pb) by Naomi Baker & Tammy Young - "Know Your Pfaff Hobbylock" covers Pfaff Hobbylock: 797, 786, 784, 783 - Great book. This book is more helpful since it has detailed info pics in color- 182 pgs, @$3.00. Lists parts, projects, etc. The 786 manual has errors, 35 pgs. not detailed as the book above. Good luck! Fairlyart
Posted on Jul 19, 2009
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
How to set Bernette serger 203 for rolled hem
Be sure you have the proper foot for your machine to make a rolled hem.
Bernette 203 How to use rolled hem foot have the one page manual but it...
Sew Inspired Serger Rolled Hem Tips
In case you don't have a manual, you may be able to glean some information here:
Sergers Overlockers
need manual for the Bernina Bernette 203 overlocker
2helpful
2answers
How do i create a rolled hem using my Platinum 750?? Do i need a special presser foot?
by rolled hem I imagine that you are trying to put something like rope in the hem to make a round edge
You can buy a 1/2 foot that allows the needle to get close to what ever is making the roll
see your local sewing machine shop
How do I do a rolled hem on aPfaff hobbylock 4760 overlocking machine
you might try youtube and see if they have a video
or try this link for a manual,they have a downloadable or hardcopy
http://www.sewingpartsonline.com/instruction-manual-pfaff-4760.aspx
1helpful
Looking for a rolled hem foot for a Hobbylock 786, lost mine?
check with these sites about the part you need--you'll have to email them about the foot
sewvacdoctor.com
a1sewingmachines.com
1helpful
What foot do i need to do the rolled hem
Hi! It's Brother part number SA126, called the 7mm hemming foot. You can order it from a Brother dealer, or from http://sewingpartsonline.com/hemmer-foot-babylock-snap-on-1.aspx
This particular foot takes a bit of practice, to get the rolled hem started, so you might want to play around with it first.
Happy Sewing!
Robbie
1helpful
Rolled hem settings
3helpful
Pfaff hobbylock serger 784 786
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
