SOURCE: paper jam in Ricoh Aficio 1515MF
Go to this link, and click on "How to clear misfeed a,p,y"
http://www.ricoh.co.uk/KBase/KBLink.cfm?ProductUID=1878
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
SOURCE: remove paper from adf error ricoh aficio 2020
Clean the paper sensors and move the actuators.Open and close front door to reset malfunction.
SOURCE: My Ricoh Aficio SP-C210SF Printer jams almost
is the machine new?
check the paper size, check the paper tray -if the paper end fence is loose(the paper should not move around).
try using fresh paper(from a sealed pack)
SOURCE: Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
