Kenmore 33169 Gas Single Oven Logo
A
Anonymous Posted on Mar 13, 2013
How to set clock on Kenmore Mark 3 stove - Kenmore 33169 Gas Single Oven
2answers
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
4helpful
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 • Ovens
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
1helpful
2answers
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 • Ovens
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Kenmore elite gas stove
f-1 means the ERC is bad. sometimes turning the breaker off for a couple of min will help but if not the the clock/oven control needs to be replaced
Nov 22, 2007 • Ovens
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
