AT&T E2562 Cordless Phone Logo
A
Anonymous Posted on Mar 13, 2013
My answering system E2562 mailbox is busy can not get the new recording of messages how do I clear this up?
Need help mailbox is busy how do I clear this up to hear the new messages recorded?
5 Related Answers
steeler38
  • Posted on Apr 01, 2008
SOURCE: remote call forwarding/message retrieval; record voice mail message
i found my solution on the AT&T website.
thanks anyway.
A
Anonymous
  • Posted on Jul 17, 2008
SOURCE: MAILBOX BUSY!
unplug the phone and it will reset
Anonymous
  • 4 Answers
  • Posted on Dec 09, 2008
SOURCE: AT&T 1855 phone with digital answering system
If Announce Only is selected, no messages will be recorded.
When Announce Select is set to "A" and the system answers a call, the caller hears the announcement you recorded, followed by a beep. After the beep, the system begins recording your caller’s message up to three minutes long.
Anonymous
  • Posted on Jul 10, 2009
SOURCE: AT&T E5965C phone answering machine does not record incoming mess
My E5965C dosenot record in comi8ng messages.
Anonymous
  • 115 Answers
  • Posted on Jun 06, 2010
SOURCE: AT cordless phone answering system does not work
yeah first you record your voice then you gotta save it as your answering machine you probibly recorded your face but not save it so goodluck:) if doesn't work send me an email ill try to find more solutions...
2answers
Phone says " mailbox is full" but all recordings have been deleted and it has 0 recordings showing.
Without know what voice mail system you are talking about you cannot be helped.
I've lost my manual and can't remember how to change and record a new the greeting. Thanks for your help. Fran
At the base unit press the MEMO button, then press one of the mailbox buttons(MAILBOX 1, MAILBOX 2, or MAILBOX 3) begin recording into the MIC at a adistance of 8 inches after the long beep. Press the MEMO button to end and save the recording. If a caller leaves a message without choosing a mailbox, the message will be recorded in mailbox 1. Here is a link to download the manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF
3answers
I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me,...
Can you please specify the exact model of the phone? Because the steps in accessing it remotely varies from model to model. Anyway, you can try to follow the steps posted here and then test:
Remote operation allows you to control the functions of the Answering System when you
are away from the Base,and call from an outside telephone line. The Answering
System cannot be accessed from another telephone on the same line. You can access
many of the Answering System functons from a remote location, such as listening to
messages, changing recorded announcements, and recording memos.
Remote operation can only be accessed from a touch tone telephone. If the remote phone
is set to pulse dialing, switch it tone. If tone dialing is not available, you will not be able
to access the Answering System.
Note: All function codes should be entered within 2 seconds in order to activate Remote
Operation.
To Activate Remote Operation From a Different Telephone Line
1. If the Answering System is OFF, you can dial your telephone number and wait for
the Answering System to answer your call after 10 rings. An announcement, "Please
enter your security code" is given, and you enter your security code to use remote
operation.
2. If the Answering System is ON, it will answer your call and begin playing the currently
selected announcement (as with any incoming call).
3. Enter # followed by your 2 digit security code during the announcement. The
default security code is 19.
4. Once the security code is received, a double confirmation beep will be given, and
you are in Remote Operation mode. You can then control the Answering Machine
functions using the telephone keypad.
5. The user can also enter the Remote Operation mode during message recording. The
procedure is the same as step 3. The recording will be stopped after entering the
valid security code "s#xx " and the incomplete message will be deleted. If " 0s"
is entered, the Answering System will release the line, but the recorded message
will still be retained.
6. If the user enters a wrong security code, the system will release the line.
Playing Messages Remotely
1. Press " #1 ", " #2 " or " #3 " on the touch tone keypad to play the messages in the
corresponding mailbox.
2. The system will announce "Mailbox X. You have XX new messages and XX old
messages" and the system will playback the new message only. If there are no new
messages, the system will announce "Mailbox X. You have XX old messages. On
the other hand, in the absence of old messages, the system will announce only the
number of new messages.
Repeat Messages During Playback
1. Press "#4" once during message playback to repeat the current message.
2. Press "#4" twice within 2 seconds to skip to the previous message.
Skip Messages During Playback
1. Press "#6" once to skip forward to the next message.
Stop Message Playback
1. Pressing "#5" during message playback will stop playback.
Deleting Messages
1. Press "#9" once during message playback to delete the current message.
Note: Playback will pause if "#" or " " is entered. Answering System will wait for the
command in the following 2 seconds. If no further tone is entered, playback will be resumed.
Memo Recording
1. Press " 8".
2. After selecting the mailbox by entering command "1", "2", "3", You will hear, "Now
recording", followed by a beep.
3. Enter "#5" to stop recording when you have finished.
Change OGM Remotely
1. Enter " 7" to record a new OGM. You will hear, "Now recording", followed by a
beep to signal start of recording.
2. Press "#5" to stop recording. Your new OGM will playback automatically.
Check OGM1 Remotely
Enter "#7" to review OGM. You will hear playback of OGM followed by a beep.
Turning Answering System ON or OFF
Pressing "#0" toggles the Answering System ON/OFF. "Answer machine on", or "Answer
machine off" will be announced, followed by a beep.
Voice Menu for Remote Operation
The system provides two pre-recorded voice menus to help you during remote operation.
Press " 5", and you will hear the simple voice menu.
The simple voice menu is as follows:
• Press "#1" to play mailbox 1.
• Press "#2" to play mailbox 2.
• Press "#3" to play mailbox 3.
• Press "#5" to stop.
• Press "#4" to repeat the message.
• Press "#6" to skip the message.
• Press "#9" to erase the message.
• Press " 5" for other functions.
(To advance voice menu)
The advanced voice menu is as follows:
• Press "#7" to review outgoing message.
• Press " 7" to record outgoing message.
• Press " 8" to record memo.
• Press "#4" twice to repeat previous message.
• Press "#0" to turn the system on or off.
• Press " 5" to return to the simple voice menu.
Pressing any function code will stop the voice menu, and perform the corresponding
functions.
Exiting Remote Operation
1. Enter " 0" on the touch tone keypad to exit remote operation mode. The Answering
System confirms your action with a long beep and then disconnects.
2. The Answering System also automatically disconnects if no key is pressed within 20
seconds during remote operation.
1helpful
Need to delete old voice message, can someone help
Erasing Messages
The unit will announce the remaining recording time after playback, if it is less than
5 minutes. New messages cannot be recorded when:
— “Memory full” is heard.
— “ ” is displayed on the base unit.
— ANSWER ON indicator flashes rapidly (only when the Answering System is on).
Erase some, or all, of the messages in a mailbox. We recommend you erase unnecessary messages after each playback.
Erasing a specific message
Press [ERASE] while the message you want to erase is being played.
• A short beep will sound and the unit will continue to play the next message.
Press [ ][4] while the message you want to erase is being played.
Erasing all messages in the mailbox
1. Press the soft key ( ).
2. Press the soft key ( , or ).
• If Mailbox 2 or 3 has a password, enter it (p. 51).
3. Press [ ][5] to erase all messages in the mailbox.
• A long beep will sound and “Mailbox (No.)” and “No messages” will be heard.
• To end remote operation, press [OFF].
I hope you rate this solution. Thank you and goodluck!
22helpful
6answers
Not able to access our main voicemail on Vodavi Starplus STS
To access the System Administrator Mailbox:
1. Dial into voice mail: From any phone on system dial 150
2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
How to program greetings
1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
2. Press [1] to access system greetings. The system will prompt you for the greeting number
3. Enter the desired greeting number.
For example:
1 = Default Day greeting
2 = Default Night greeting
3 = Default Temporary greeting
4. You will be prompted with the following three choices:
Press [1] to Review.
Press [2] to Record. You will be prompted to record the greeting
When you finish recording, press [#] to save the recording.
You can then
Press [*] + [*] + [*] to exit the system completely
2answers
Record a Primary message
It sounds like the recording for 22 may not be the one answering the call. another mailbox, say 10 the general elivery mailbox may be answering, this is the one you need to change.
Dan
MAILBOX BUSY!
Panasonic KX-T7633. Phone message box is busy
This, my friends, is a very popular problem. It is caused by someone else in your company pressing the Message button on their phone while you are calling them or they are calling you. We strongly recommend to our customers that no one presses the Message button under any circumstances. To access your voice mailbox, always dial the Automated Attendant access code assigned by your installer - usually 165 (although on our systems it is "62" or the letters "MB" for MailBox).
You need to dial the Message Waiting Lamp feature code and dial "0" for the extension number. The code itself varies from system installation to system installation, but the most likely numbers are *70 and 70.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
2helpful
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
