At turn on red lite blinks twice and goes off and tv does not come on relay clicks when you turn on and clicks off 15 -20 minutes later
SOURCE: LG 50PC3D PLASMA WILL NOT TURN ON
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you save $300 least!
SOURCE: I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
SOURCE: Panasonic plasma th42ph10uk power red light blink twice
Manual says problem with SC, SS, or C boards. SC is large board at left when facing rear, SS is large board at right, and C is small long board at very top. You could check fuses on SC and SS. Also, SC and SS should make a buzzing noise(not too loud) if operating. If a fuse is blown, suspect that board is bad not just bad fuse. Search parts at encompassparts.
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions
Any less obvious answers
